Differences Between Impulse & Idle Impulse Response in Digital Comm
Thread startervijbele
Start date
Impulse response in digital communication refers to how a system reacts over time to a brief input signal, providing insight into its filtering characteristics. Idle impulse response, while less commonly referenced, may pertain to the system's behavior when no active signals are present, potentially highlighting noise or baseline performance. Understanding both responses is crucial for analyzing system performance and optimizing communication protocols. The distinction between these two responses can impact the design and evaluation of digital communication systems. Clarifying these terms enhances comprehension of their applications in various digital communication contexts.
#1
vijbele
Difference between the impulse response and idle impluse response interms of digital communication.
Could you clarify that a bit, please?
Background and where the terms apply together might help.
I am familiar with the term impulse response. It refers to the time domain response of a filter to an impulse (analogue or digital) - but it's a very general term. I haven't heard of 'idle response'.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hi Guys
We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns.
What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design.
Any help will be appreciated.
Thanks.
edit: even same wire diameter and coil was wounded by a...
