Differential eq with square root numerical
The discussion revolves around solving a system of coupled nonlinear ordinary differential equations, specifically focusing on the numerical solution of the equation x'(t)=(1-x(t))^(1/2) with an initial condition. Participants explore issues related to oscillations in numerical solutions and the challenges posed by the square root term in the equation.
  • One participant describes experiencing violent oscillations in the numerical solution due to the square root term approaching zero, leading to complex values.
  • Another participant requests the formulation of the system to better understand the problem.
  • A participant notes that starting the initial condition at x(2)=1 yields a constant solution, suggesting the importance of the initial condition in numerical methods.
  • Some participants propose using Newton's method as an alternative approach, emphasizing the need for a reasonable first guess for convergence.
  • One participant suggests hard-coding the algorithm to navigate the multi-sheet nature of the square root function to avoid complex values.
  • Another participant provides a Mathematica code snippet using a modified Euler method that maintains the correct path over the Riemann surface of the complex square root, claiming it yields the desired answer.
  • Concerns are raised about the standard numerical analysis overshooting the branch-point of the square root, leading to imaginary components in the solution.
Participants express a range of views on how to approach the numerical solution, with some advocating for specific methods like Newton's or modified Euler, while others highlight the challenges posed by the square root term. No consensus is reached on a single method or solution approach.
The discussion highlights limitations related to the behavior of numerical methods near branch points and the impact of initial conditions on the stability of solutions. The complexity of the square root function introduces additional challenges that remain unresolved.
xapiens
Hi!
I have to solve a system of two coupled nonlinear ordinary differential equations. In the function that defines the system there are terms with square root of the dependent variables. I tried to solve the system numerically but in the nmerical solution I get violent oscillations. Then I realized that the same problem appears in the numerical solution of this very simple exactly solvable differential equation: x'(t)=(1-x(t))^(1/2) with initial condition x(2.1)=0.9975. The exact solution is x(t)=(1/4)(4t-t^2).
It seems to me that the problem is the square root (1-x(t))^(1/2). When the numerical solution approach an extremum, then x'(t) and (1-x(t))^(1/2) both approach zero. But then (1-x(t)) also approaches zero, and in fact (1-x(t)) takes negative values, that makes the square root imaginary.
I explore the situation with the fourth-order Runge-Kutta method with step h=0.2 and in the firt iteration I find the complex value:
x(2.1)=1.00463+ 0.0042963 I
The same happens with the Euler method and the MidPoint Method
Any hint of how to get the correct numerical solution of this equation?
Thanks a lot!
Can you write the system down.
Hi!
Initially I want to get the numerical solution of this very simple system.
x'(t)=(1-x(t))^(1/2) with initial condition x(2.1)=0.9975.Also I note that if I start with initial conditions in the maximum x(2)=1, the RK4 gives contant solution x(t)=1. That is the reason I have to start with x(2.1)=0.9975.
You know that you can solve that analytically right? Another way to tackle this problem is by Newton's method, you define your points [itex]t_{i}[/itex], then you write down your equation at the point [itex]t_{i}[/itex], this then will lead to you computing the Jacobian and then it should only take a few iterations to get the answer.
Yes! I know the exact solution. But I need to get the numerical solution of the differential equation. It is a warm up to a harder equation with similar problems.
I found that Newtons method works very well for this kind of thing but you have to have a reasonable first guess though, or at least something random that the iteration can work with.
Thanks a lot!
You could hard-code the algorithm to follow the correct path over the underlying multisheet of the square root function, or eliminate the multi-function from the differential equation:
[tex]x'=\sqrt{1-x}[/tex]
[tex]x''=1/2(1-x)^{-1/2}(-x')[/tex]
[tex]x''=-1/2\frac{x'}{\sqrt{1-x}}[/tex]
[tex]x''=-1/2[/tex]
Now, in place of your original DE, use:
[tex]x''=-1/2;\quad x(t_0)=x_0,\quad x'(t_0)=\sqrt{1-x}[/tex]
Jackmell, I think that this is a little specialised for the problem in hand (although it is a rather nice solution), it is just a warm up problem for him, I think he is asking for a more general method.
Let's do the easy one first:
The code below is the first approach in Mathematica using a modified Euler-method which maintains the correct path over the multisheet (Riemann surface of the complex square root).
Code:
platch = True;
xold = 0;
thet = 0;
a = 1;
dh = 0.01;
myvals = Table[temp = 1 - xold;
     If[platch == True && temp < 0,
      {xold = 2 - xold; platch = False; a = -1; }];
     xnew = xold + a*Sqrt[1 - xold]*dh;
     xold = xnew; {thet += dh, xnew}, {n, 1, 500}];
ListPlot[myvals, PlotStyle -> Red, Joined -> True]
And that gives the desired answer. Anyway, I think the problem with a standard numerical analysis of this DE, is that the algorithm is passing through the branch-point where the two branches of the root meet and since delta h is finite, it over-shoots the branch-point landing on a surface which has an imaginary component. In the algorithm above, I force the algorithm to follow a path which is always real. Maybe though I don't have this quite presented right but that's what I'm sticking with for now.
How about posting the harder one xapiens.
  • · Replies 24 ·
  • · Replies 0 ·
