Saladsamurai
- 3,009
- 7
y''' + 2y'' - 3y' = 0
I solved the above using the following, where D is the differential operator:
D(D - 1)(D + 3)y = 0
Let u(x) = (D + 3)y
Hence,
(D2 - D)[u(x)] = 0. This 2nd Order in u(x), linear, homogenous with constant coefficients. Hence the solution given by characteristic equation is (from lambda = {0,1}):
u(x) = C1 + C2*exp(x)
Plugging this result back into the factorized DE:
(D + 3)y = C1 + C2*exp(x)
y' + 3y = C1 + C2*exp(x)
which can be solved by integration factor:
y(x) = (1/3)*C1 + (1/4)C2*exp(x) + C3*exp(-3x)
Checking with Wolfraalpha gives:
y(x) = (-1/3)*C1*exp(-3 x)+C2*exp(x)+C3
which looks similar to mine, but is a little off. Namely the negative sign and the fact that the factor of (1/3) is associated with an exponential and my factor of (1/3) is associated with a constant only.
Any thoughts on this?
Also: Would it be appropriate to simply write (1/3)*C1 as just plain old C1? that is, can't I just "absorb" all of the numerical coefficients into the parametric coefficients?
thanks!
