Differential equation on relativistic momentum (ML Boas)
agnimusayoti
The momentum ##p## of an electron at speed ##v## near the speed ##c## of light increase s according to the formula ##p=\gamma mv##, where ##\gamma = \frac{1}{\sqrt{1-v^2/c^2}}##; m is a constant (mass of an electron). If an electron is subject to a constant force F, Newton's second law describing its motion is: $$\frac{dp}{dt}=\frac{d}{dt} \gamma mv=F$$. Find (a) v(t) and show that v approaches c as t approaches infinite. (b) Find the distance traveled by the electron in time t if it starts from rest.
For ##dy/dx = c##, the solution is $$y=\int {c dx}$$
$$p=\gamma m v$$
$$F = \frac {md (\gamma v}{dt}$$
$$\int{F dt} = \int{md (\gamma v}$$
$$F t= \gamma mv$$
At this step, I don't know how to make v as explicit function of t, since gamma is a function of v too. Thankss
Gee, I think I just have to take quadrat on both sides. Pfft..
Now, I will update what I get and still can't get the distance function.
I get:
$$v^2=\frac{Ft}{m^2+\frac{Ft}{c^2}}$$, then
$$v=\sqrt{\frac{Ft}{m^2+\frac{Ft}{c^2}}}$$
Writing ##v=\frac{dx}{dt}## gives:
$$\frac{dx}{dt}=\sqrt{\frac{Ft}{m^2+\frac{Ft}{c^2}}}$$
Any suggestion how to determine this integral?
It's easier if you start with the correct expression for v.
I get:
Try again. What does squaring both sides of mv = Ft/\gamma(v) give you?
Shoot. I forget to square Ft. Sorry,
Youre right.
I get this:
$$dx=\frac{cF t}{\sqrt{m^2 c^2 + F^2 t^2}} dt$$
Then, integrating this equation, I get:
$$x=\frac{c}{F}\sqrt{m^2c^2 + F^2t^2} + C_1$$
Because electron starts from rest, therefore at t=0 x = 0. So, I get ##C_1=-\frac{mc^2}{F}##.
Using this constant, I get the same answer with the solution.
Thanks. Sorry for not being meticulous.
