Differential equations assignment T3
20 replies · 5K views
mathi85
Hi!
I would like to ask anyone with some spare time to check my assignment questions. Last time I was asked to post one task at a time so I will.
Thank you in advance for your time.
Task 3:
A capacitor C is charged by applying a steady voltage E through a resistance R. The p.d. between the plates, V, is given by the differential equation:
CR(dV/dt)+V=E
a) Solve the equation for E given that when time t=0, V=0.
b) Evaluate voltage V when E=50V , C=10μF, R=200kΩ and t=1.2s
Solution:
a)
I want: (dV/dt)PV=Q
CR(dV/dt)+V=E /:(CR)
(dV/dt)+(1/CR)V=E/(CR)
P=1/(CR) and Q=E/(CR)
Integrating factor =e∫ P dt
∫ P dt=∫ 1/(CR) dt = ln(CR)t
IF=eln(CR)t=CRt
y(IF)=∫ (IF)*Q dx
∴V(IF)=∫ (IF)*Q dt
VCRt=∫ CRt*(E/(CR)) dt
VCRt=∫ tE dt
VCRt=(Et2)/2+c
General Solution:
VCRt=(1/2)Et2+c
t=0 when V=0
∴0=0+c
c=0
Particular Solution:
VCRt=(1/2)Et2 /*2
2VCRt=Et2 /:t2
E=(2VCRt)/(t2)
b)
VCRt=(1/2)Et2 /:CRt
∴V=(1/2)[(Et2)/(CRt)]
V=(1/2)[(50*1.22)/(10*10-6*200*103*1.2)]
V=30volts
mathi85 said:
Hi!
Task 3:
CR(dV/dt)+V=E
Solution:
a)
I want: (dV/dt)PV=Q
Where did this come from?
You didn't integrate correctly. R and C are constants.
IF=eln(CR)t=CRt
This is wrong too. It's true that eln a=a, but that's not what you have here because of t.
y(IF)=∫ (IF)*Q dx
∴V(IF)=∫ (IF)*Q dt
VCRt=∫ tE dt
VCRt=(Et2)/2+c
General Solution:
VCRt=(1/2)Et2+c
t=0 when V=0
∴0=0+c
c=0
VCRt=(1/2)Et2 /*2
2VCRt=Et2 /:t2
E=(2VCRt)/(t2)
b)
VCRt=(1/2)Et2 /:CRt
V=30volts
Sorry! It should be:
"I want: (dV/dt)+PV=Q"
This is just to remind me what form the equation should have.
I'll try to get my head round this integration...
I really struggle with this integration involving 1/CR.
Is it just 1/(CR)*t and my IF will be e1/(CR)*t?
I understand that because CR are constants, not functions I cannot have it as ln.
Thnx! I'll do it again and post it asap.
Now it makes even less sense to me:
∫ P dt = ∫ 1/(CR) dt = t/(CR)
∴IF=et/(CR)
Vet/(CR)=∫ et/(CR)*E/(CR) dt
I'm not sure about the integration. If I treat E/CR as number then I can go:
Vet/(CR)= (CR)/E∫ et/(CR) dt
This is fine:
$$Ve^{t/RC} = \int \frac{E}{RC}e^{t/RC}\,dt.$$ You're correct that E/RC is a constant so that you can pull it out of the integral; however, this isn't correct:
$$Ve^{t/RC} = \frac{RC}{E}\int e^{t/RC}\,dt.$$ Why did you flip the fraction over when you pulled it out of the integral? It should be
$$Ve^{t/RC} = \frac{E}{RC}\int e^{t/RC}\,dt.$$ Now use the substitution u = t/RC.
Sorry. I was tired last night and started making stupid mistakes.
I understand that now I have to use integration by parts method however in examples I've done so far I always had two functions of x, i.e. ∫ x*e2x dx
In this case I know that:
u=x
du/dx=1
dv/dx=e2x ∴ v=(1/2)e2x
and:
∫ u(dv/dx) dx = u*v-∫ v*(du/dx) dx
So if u=t/(CR), what is my dv/dt and v?
Did you mean I should use a simple substitution?
Veu=E/(CR)∫ eu dt
I keep trying... This is what I have now:
Vet/(CR)=E/(CR)∫ e[1/(CR)]t dt
Vet/(CR)=E/(CR)*CRet/(CR)+c
Right I come to the point where:
Ve(1/(CR))t=Ee(1/(CR))t+c /:e(1/(CR))t
V=E+c/(e(1/(CR))t)
if I apply t=0 when V=0
0=E+c
c=-E
and Part. Sol.
V=E+[-E/e(1/(CR))t]
Where am I going wrong?
I'm getting that E=V+E/e(1/(CR))t
This cannot be right can it?
It just didn't look right to me.
Thank you very much for your help!
