Differential equations - cannot solve one
luuurey
Greetings everyone.
Can you help me please with solving this differential equation?
\large \frac{dv}{dt} = a_g + \alpha v^n
where \Large a_g \alpha n are constants. Artelnatively with specific n as n = 1, 2.
I have no idea what to do...
Thank you very much
It seems quite simple at the first glance, as the equation is separable.
The first thing I'd do is to separate the two variables to get \displaystyle \frac{dv}{a_g+\alpha v^n}=dt. From there, you integrate both sides.
The "trick" here is that the left hand side doesn't seem integrable. In fact, it isn't very easy and pleasant to integrate for most n's, but it can be done. I can't find a general algorithm though.
Okay. Let's say n = 1. Then it should be resolvable. And what if n = 2 ? For n = 0 it is trivial...
For n=1 a simple substitution will give you log. For n=2 a trig substitution will get you an arctan.
Can you show me please ?
How does it give you arctan ?
What is \displaystyle \ \ \int\frac{dx}{1+x^2}\ ?
Have you never taken a Calucus class? If n= 0, The integral is just
\int \frac{dv}{a_g+ \alpha}= \frac{1}{a_g+ \alpha}\int dv
If n= 1 it is
\int\frac{dv}{a_g+ \alpha v}
If n= 2 it is
\int\frac{dv}{a_g+ \alpha v^2}
Can you integrate those?
No, I haven't. I do not know how to substitute. The first one I can. The next two I cannot.
What is the derivative of arctan(x) ?
For integrals of the type
\int \frac{dx}{a^2 +x^2}, try the following substitution :
x=a \tan \theta
With a bit of algebra, you'll be able to put your integral at this form.
x=a \tan \theta
dx=\frac {a} {\cos^2 \theta} d \theta - is it like this ?
so we get:
\frac {1}{a^2}\int \frac{\frac{a}{\cos^2}d \theta}{1 +\tan^2 \theta} = \frac {1}{a}\int \frac{d\theta}{\cos^2\theta +\sin^2 \theta} = \frac{\theta}{a} = \frac {\arctan \frac{x}{a}}{a}
Okay and what next ?
x=a \tan \theta
so we get:
Fine. Now, compare the two integrals and identify your "a".
Well
a = \sqrt{a_g} \\<br /> x = \sqrt{\alpha}v
So I got
\frac {\arctan({\sqrt{\frac{\alpha}{a_g}} v})}{\sqrt{a_g}} = t
didn't I?
So
v = \frac {\tan(\sqrt{a_g}t)}{\sqrt{\frac{\alpha}{a_g}}}
IS IT RIGHT ?
luuurey said:
Well
So I got
didn't I?
So
IS IT RIGHT ?
Actually, do this:
\frac{1}{\alpha} \int \frac{dv}{\frac{a_g}{\alpha}+v^2}
Then, use the substitution to integrate.
JasonPhysicist said:
Actually, do this:
I would get the same, wouldn't I ? One thing I'd like you to tell me. How do you know what subtitution you have to use?
Not exactly. Notice there's an \sqrt \alpha missing on the denominator.
Btw, I know the substitution simply by having done similar integrals many times over. Also, you can get the idea if you remember the usual trigonometric identities.
Got it. So you say it's all about practise, like in normal algebra, right?
Exactly. After some time, you'll just get used to it.
I found a general algorithm to integrate these kinds of functions.
You do a partial fraction decomposition using complex numbers. You'll need the nth roots of unity for this. An example is \dfrac{1}{1+x^4}, which can be decomposed using the equality 1+x^4=(x-\sqrt{i})(x+\sqrt{i})(x-i\sqrt{i})(x+i\sqrt{i}) where \sqrt{i}=\dfrac{\sqrt{2}}{2}(1+i) from Euler's identity. This leaves you with 4 fractions with denominators of degree one. In general, this yields an expression with the hypergeometric function involved, but it can be simplified for integer n to an expression involving only the complex logarithm (or real logarithms + inverse tangent.)
