Differential Equations-Finding Constants
Bashyboy
Differential Equations--Finding Constants
I uploaded a pdf document, which contains the problem I am currently working on, namely, problem number 7
I am having particular difficulty with this portion of the solution:
"(ii) At y=3, the function ay+b changes from positive to negative
--> ay+b has a negative slope --> a is negative"
Why does "a" being negative follow from these facts? Also, why does a function change signs at y = 3?
Two lines above, it was shown that ay + b > 0 when y < 3, and ay + b < 0 when y > 3. That literally means that it changes its sign at y = 3. And because it goes from positive to negative, it has to have a negative slope. Now this function is a simple straight line, so its slope = a, hence a must be negative.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
