Differential Equations, solve the following: y^(4) - y'' - 2y' +2y = 0
The discussion revolves around solving a fourth-order linear homogeneous differential equation, specifically y^(4) - y'' - 2y' + 2y = 0. Participants are exploring the characteristic equation associated with the problem and considering the implications of a provided hint regarding a known solution.
  • Participants are attempting to derive solutions using the characteristic equation and are questioning the completeness of their findings. There is discussion about factoring polynomials and identifying roots, with some participants expressing uncertainty about the usefulness of certain approaches. The hint regarding a known solution prompts consideration of additional solutions.
The conversation is active, with participants sharing their attempts at solving the characteristic equation and discussing the implications of the roots they have found. Some guidance has been provided regarding the identification of additional solutions based on the hint, but there is no explicit consensus on the best approach to take.
Participants are navigating the complexities of polynomial factorization and the implications of double roots in the context of the differential equation. There is an acknowledgment of the algebraic challenges involved in the problem-solving process.
komarxian
Solve the following differential equations/initial value problem:
y^(4) - y'' - 2y' +2y = 0 Hint: e^-x sinx is a solution
I was attempting to solve this problem by using a characteristic equation.
y'''' -y'' -2y' + 2y = 0 --> r^4 -r^2 -2r +2 = 0
r^2(r^2 - 1) -2(r - 1) = 0
r^2 (r+1)(r-1) -2(r-1) = 0
(r^2(r+1) -2)(r-1) = 0
from this I get r = 1, but I know there are more solutions; How do I solve for the other solutions? And then write it as the solution?
This isn't a useful approach, IMO, unless you are able to factor the cubic polynomial.
Use the given hint. If ##y = e^{-x}\sin(x)## is a solution, then another solution is ##y = e^{-x}\cos(x)## is also a solution. This means that ##r_1 = -1 + i## and ##r_2 = -1 - i## are roots of some quadratic characteristic equation.
You have ##p(r) \equiv r^2 - r^2 -2r+2 = (r-1)(r^3+r^2-2).## Notice that the polynomial ##q(r) = r^3+r^2 -2## has a root ##r = 1##, so ##(r-1)## is a factor. That gives ##q(r) = (r-1)(r^2+2r+2) ##, hence ##p(r) = (r-1)^2 (r^2+2r+2).## Thus, ##r=1## is a double root of ##p(r)## and the other roots are found by solving a simple quadratic equation.
Thank you!
Thank you! I get it now; got to work on the algebra XD
I've got 99 problems and it's all algebra pretty much.
You say that solving the characteristic equation may not be useful. However, sometimes that's all you can do. For example, the differential equation ##y''' - 2 y''
+3 y' - 4 = 0## has characteristic equation ##r^3-2 r^2+3 r - 4 = 0##. This can be solve usingCardano's formulas (for example), but that is really not a useful way to go: numerical solutions are far preferable. That gives the solutions as ##y_1 = e^{rx},## ## y_2 = e^{\alpha x} \cos(\beta x)## and ##y_3 = e^{\alpha x} \sin(\beta x),## where ##r \doteq 1.650629192,## ##\alpha \doteq 0.1746854042## and ##\beta \doteq 1.546868888.##
I didn't say that solving the char. equation wasn't useful in this case, if the OP wasn't able to get other solutions out of the remaining cubic polynomial.
  • · Replies 18 ·
  • · Replies 24 ·
