Why Are Differential Equations Considered Difficult?
In summary, the conversation discusses differential equations and why they are considered difficult. It is explained that people have different abilities in solving abstract problems and that Calculus can be challenging for some. Differential equations involve derivatives and finding a solution can be difficult depending on the equation. The key to solving differential equations is understanding the solution beforehand and having a strong understanding of functions, algebra, and calculus. There are methods and tools that can make solving differential equations easier, such as integrating factors and separation of variables. A useful website for learning more about differential equations is also mentioned.
Rockazella
96
To start off I know nothing about them. My question is why are they considerd so difficult?
I'm in a precalc class and would like to study some higher level math on my own time. I have heard that these equations are very difficult to solve or understand or something, just wondering what makes this so?
Mathematics news on Phys.org
People differ greatly
in their ability to solve abstract problems. Most don't have much trouble with Algebra or Geometry, but for some reason Calculus seems to separate those with abstract abilites from those who don't.
a differential equation is an equation with some kind of derivative in it. for instance dy/dx + y = 1. This is saying the function plus the first derivative of that same function is always equal to 1. There would be a family of y's that you could plug into this equation and that would be called the solution of the differential equation. Sometimes finding a solution can be difficult be sometimes its really really easy. For this equation it would be very easy, but for sin(x) * dy/dx + y = 1 it would be more difficult. So difficutly just depends on the particular equation.
For the most part normal algebraic equations can be solved nearly mechanically, follow the rules, crank the handle of the machine and out pots a solution.
Such is not the case for differential equations, there are methods to use if certian conditions are met, and there are some which simply cannot be solved analytically.
The difficuty comes in learning when to apply which methods.
The key to solving most differential equations is knowing the solution befor you start. When you solve an algebraic equation the solution is a simple variable, the solution to a DE is a function, for many types of DE we can recognize the general function which solves the equation.
For example a DE of the form
X(t)"+ λX(t) = 0
has a general solution
of X(t)= ACos(λt)+ Bsin(λt) OR
X(t) = Aeλt+ Be-λt
Where A and B are constants.
A and B cannot be determined with the information I have provided, the complete statement of a DE includes either Boundry condions, that is the value of the solution at some point (usually an end point) or an initial value (if the independent varialbe is time) which specifies the value at some time.
I really cannot present a course in DE, but perhaps you can see parts of the quest that lie ahead of you.
To really get an understanding of DE you need to understand functions, you must have a mastery of algebra and a good understanding of calculus, both differential and integral.
Good luck.
another "making it easy" factor
Hello string,
When it comes to diff eqn there is a cool tool called an integrating factor: e^[f'(x)]which is as important to calculus as L'Hospital's (that's how Google spells it)Rule is to topology or Avagadro's Number is to Chemistry. Properly used the factor works magically on EQs that appear to be insoluable.
The most important rule in EQ that a beginner needs to respect is "separation of variables: E.g., dy/dx = yx^2 multiply thru by "ydx" gives ydy =[x^2]dx Both sides are now integratable and are equal [excepting some arbitrary integrating constant]. Cheers Jim
This prooves to be a useful site:
http://www.physics.ohio-state.edu/~physedu/mapletutorial/tutorials/diff_eqs/intro.html
What are differential equations?
Differential equations are mathematical equations that describe how a quantity changes over time. They involve derivatives, which represent the rate of change of the quantity, and can be used to model a wide range of phenomena in science and engineering.
What are the different types of differential equations?
The three main types of differential equations are ordinary differential equations (ODEs), partial differential equations (PDEs), and stochastic differential equations (SDEs). ODEs involve a single independent variable, while PDEs involve multiple independent variables. SDEs take into account random variables and are often used in modeling systems with uncertainty.
What are some real-world applications of differential equations?
Differential equations are used in many fields of science and engineering, including physics, biology, economics, and engineering. They can be used to model the motion of objects, the growth of populations, the spread of diseases, and the behavior of electrical circuits, among other things.
What techniques are used to solve differential equations?
There are several techniques for solving differential equations, including separation of variables, substitution, and using integrating factors. Some equations can be solved analytically, while others require numerical methods such as Euler's method or the Runge-Kutta method.
Why are differential equations important in science?
Differential equations are important because they allow us to describe and predict the behavior of complex systems in the natural world. By using mathematical models based on differential equations, scientists and engineers can better understand and control these systems, leading to advancements in technology and our understanding of the world around us.
  • General Math
  • Science and Math Textbooks
  • STEM Academic Advising
  • Differential Equations
