Differentiating force to find potential energy
The discussion focuses on deriving the potential energy of a particle subjected to a force F(x) = -kx. The potential energy can be expressed as V = -∫F(x') dx' from an arbitrary position x0 to x. One participant initially struggled with the integration but later clarified that the left-hand side does not need explicit integration. Ultimately, the correct potential energy expression is confirmed as V = (1/2)kx^2. The conversation emphasizes the importance of understanding the relationship between force and potential energy in conservative systems.
Saxby
A particle of mass m is moving along the x-axis and experiences a force F(x), also along the x-axis, given by F(x) = -kx. Deduce an expression for the potiential energy of the particle.
I tried intergrating both side (just to see if it gave me anything helpful). I got ∫F(x)dx=mv for the left hand side and -(1/2)kx^2 on the right hand side but i still don't have the answers. Any help would be much appreciated :)
The potential energy at some position ##x## of an object subjected to a conservative force (in one dimension) is ##V = -\int_{x_0}^{x} F(x') dx'##. ##x_0## is arbitrary, since you can set the zero potential anywhere you like. You didn't need to integrate the left hand side explicitly.
Edit: Also, don't erase the homework help template. It's there for a reason, as this example demonstrates.
Ok, I've found the answer and i understand how to do it. Thanks for your help :)
