Differentiation of unitary operator U(t,t') in Peskin and Schroeder
Romanopoulos Stelios
How the authors came to the conclusion (eq. 4.25) that
$$ U(t,t')=e^{iH_0(t-t_0)} e^{-iH(t-t')} e^{-iH_0(t'-t_0)} $$
You can plug the expression into equation 4.24 to verify it's correct. The left side is (taking into account the non-commutativity of ##H_0## and ##H##):
$$i\frac{\partial}{\partial t}U(t,t')=i\left[e^{iH_0(t-t_0)}(iH_0)e^{-iH(t-t')}e^{-iH_0(t'-t_0)}+e^{iH_0(t-t_0)}(-iH)e^{-iH(t-t')}e^{-iH_0(t'-t_0)}\right]=\underbrace{e^{iH_0(t-t_0)}(H-H_0)e^{-iH_0(t-t_0)}}_{H_I(t)}\underbrace{e^{iH_0(t-t_0)}e^{-iH(t-t')}e^{-iH_0(t'-t_0)}}_{U(t,t')}$$
this is nothing but the right hand side of 4.25. In the second line I've used ##1=e^{-iH_0(t-t_0)}e^{iH_0(t-t_0)}##, ##H_{int}=H-H_0## and the definition of the interaction picture Hamiltonian.
You may not see this answer, but as an individual memo, I answer your question.
From eq. (4.18), you can get
$$ H_I(t) = \left( i \frac {\partial} {\partial t} U(t,t_0) \right) U^\dagger(t,t_0). $$
Then, substitute this eq. for the right-hand side of eq. (4.24).
If you do so,
\begin{align*}
& (\text{right-hand side of (4.24)}) \\
& = H_I(t)U(t,t') \\
& = \left( i \frac {\partial} {\partial t} U(t,t_0) \right) U^\dagger(t,t_0) U(t,t') \\
& = i \frac {\partial} {\partial t} \left( U(t,t_0)U^\dagger(t,t_0)U(t,t') \right)
- U(t,t_0) i \frac {\partial} {\partial t} \left( U^\dagger(t,t_0)U(t,t') \right).
\end{align*}
Since ##U(t,t_0)U^\dagger(t,t_0)=1##, if you substitute this for (4.24) you get
$$ \frac {\partial} {\partial t} \left( U^\dagger(t,t_0)U(t,t') \right) = 0. $$
From this,
$$ U^\dagger(t,t_0)U(t,t') = C(t') ~~~~ (C(t')\text{ is an arbitrary function of }t'). $$
Now, since ##U(t,t')=1## for ##t=t'##, ##C(t') = U^\dagger(t',t_0)##.
Therefore,
$$ U(t,t') = U(t,t_0)C(t') = U(t,t_0)U^\dagger(t',t_0) = e^{iH_0(t-t_0)}e^{-iH(t-t')}e^{-iH_0(t'-t_0)}. $$
That's all.
:welcome:
Note that this thread is five years old!
PeroK said:
:welcome:
Yeah, I know (ゝω・)
This is for the people who couldn't find how to derive (4.25) from (4.24).
thx!
The problem will occur if ##H## is dependent on time. We must perform derivative ##H## in the component ##\exp\left[-iH(t-t_0)\right]##
$$ i\frac{\partial}{\partial t}\exp\left[-iH(t-t_0)\right] = \frac{\partial H}{\partial t}(t-t_0)\exp\left[-iH(t-t_0)\right]+H\exp\left[-iH(t-t_0)\right] $$
And do we ensure that ##H## is independent on time?
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
