Differentiation problem square root function
CrossFit415
I'm on mobile so I can't use latex.
Differentiate:
g(x)=√(4-x^4) , x is a set of [-√2, √2] and determine the domains.
So I got the derivative which is,
g'(x)=(-4x^3) ^1/2
What should I do with the -+√2 ?
I don't know what to do next
Differentiate:
g'(x)=(-4x^3) ^1/2
Nope. You need to use the chain rule. It will help to write your function as
g(x) = (4 - x4)^(1/2)
Alright
I have
g'(x) = 1/2(4-x)^-1/2 • -4x^3
Then how would I determine the domains? I know 4-x^4 >= 0. So what about the two square roots?
What should I do with the +/-√2 ?
It's still not right. Check your work.
Since your original is named g, its derivative is g', not G'.
The domain of g is the interval [-\sqrt{2}, \sqrt{2}]. The domain of the this derivative will be exactly the same, with the possible exception of the endpoints.
CrossFit415 said:
I have
G'(x) = 1/2(4-x)^-1/2 • -4x^3
NO. Do it again and show each step.
The domain will be the intersection of the natural domain of the derivative (not what you have above) and the given domain of the function, [-\sqrt{2}, \sqrt{2}].
g'(x) = 1/2(4-x^4)^1/2-1 • d/dx (4-x^4)
= 1/2(4-x^4)^-1/2 • -4x^3
Should I keep continuing?
Then
= -2x^3(4-x^4)^-1/2
Please do NOT use "x" both as the variable and for multiplication!
Sorry!
Then
= -2x^3(4-x^4)^-1/2
Much better.
When you write expressions on a single line, you need to use more parentheses. The above should be written as -2x^3(4-x^4)^(-1/2).
Mark44 said:
Much better.
Thanks! Ohh ok I ll be sure to use more parenthesis next time.
So should I just plug in +/- √2 for x to find the domains? Or leave it alone? Are the domains just +/- √2 ?
Your question was answered twice in this thread.
I don't think you understand what "domain" means - it's not domains. The domain (singular) is the set of numbers at which the relevant function is defined.
