Differentibility of a function
  • Thread starter james007
  • Tags
    Function
In summary: Sorry, I meant decreasing. A typo. So we have [ g(x) - g(0) ] / x is approaching 0 this means there exists some y such that g'(y) = 0. A contradiction since above we assume that g'(x) <...Since g' is always decreasing, there must be a point where g(x) = 0. I don't know how to find this point.Since g' is always decreasing, there must be a point where g(x) = 0. I don't know how to find this point.
james007
Can someone help me with this?
Let f: R into R be differentiable
1) If there is an M strictly less than 1 for each x in R, f'(x) strictly less than M,
prove that there exists a unique point x such that f(x)=x. ( Note: x is a fixed point for f)
2) Give counter example to show 1) fails if M=1.
What have you tried? (Hint: Consider the function g(x) = f(x) - x)
Thanks for your help. I just have no clue how to approach this problem.
By assumption, we have for each x in R, there exists M < 1 such that f '(x) < M . I just don't know what to do with this given info. Can you elaborate a bit?
Consider g(x) = f(x) -x , then g(x) is also differentiable. So g(x) has the given property as f(x) . For each x in R, there exists M < 1 such that g '(x) = f '(x) - 1 < M. Am I on the right track? I don't know how to get to f(x) = x from here.
well for starters, what if there were two such points? what would the mvt say?
Try looking at the derivative of g. f'(x) < M < 1 implies that f'(x) - 1 < ?
for existence just take any value of x at all, say a, and look at the point (a, f(a)).
now suppose the derivative of f is always less than say 1/2.
pass a line with slope 1/2 through your point (a,f(a)). how is the graph of your function situated wrt this line?
wrt the line y=x?
If there were two such points x, y. Wlog, let x < y, then by MVT, there exists z in (x,y) such that
f(y) -f(x) = f '(z) * (y-x) . Then for each z , there exists M < 1 such that f '(z) < M . So, f(y) - f(x) < M * (y-x) , i.e.( ( f(y) - f(x) ) / (y-x) ) < M ?
Derivative of g implies that f '(x) - 1 < M , which I already stated above. But the inequality f '(x) < M < 1 implies that f '(x) - 1 < M -1 < 0 right?
Right. Now what does that tell you about the global behavior of the graph of g?
I don't quite get the term "global behavior" . Can I say that the graph of g assumes max and min?
Can g have a max and min with a derivative function that is always negative and never approaches 0?
No, if g' is always negative, then g is increasing. What does this say about f(x)?
if a point on the graph of f is above the line y=x, and the graph of f is always below the line y = cx where c < 1, doesn't that say the graph of f must cross the line y=x?
(since the graph of y = cx does so.)
Yes, it must cross the line y=x. So from here I get the existence of x where f(x)= x ?
No, it says that g is always decreasing. Since g is defined on all of R, can a such a function be defined that never passes through 0?
Sorry, I meant decreasing. A typo. So we have [ g(x) - g(0) ] / x is approaching 0 this means there exists some y such that g'(y) = 0. A contradiction since above we assume that g'(x) < 0 for all x.
Can you help me with the counterexample when M=1?
Can you explain this argument more distinctly? I'm not sure why we are looking at the derivative of g at x=0.
Consider why you are given the information that f'(x)<M<1 and not simply f'(x)<1. Why is M necessary for the proof to work? Can you think of a type of function that is defined on all of R and always decreases but never crosses the x-axis?
slider142 said:
Can you explain this argument more distinctly? I'm not sure why we are looking at the derivative of g at x=0.Consider why you are given the information that f'(x)<M<1 and not simply f'(x)<1. Why is M necessary for the proof to work? Can you think of a type of function that is defined on all of R and always decreases but never crosses the x-axis?
You told me to consider the function g(x) = f(x) -x. So, if there exists x such that f(x) =x , then g(x) must be equal to 0 for some x. By contradiction, I assume that g(x) doesn't equal 0 for all x. Pick x= 0 , g(0) does not equal 0 by the assumption I just made. There are two cases: g(0) < 0 and g(0) > 0. By MVT, I reach something that contradicts the fact g'(x) < 0 for all x.
I still need to show uniqueness of x. Do you think I can use the typical approach by assuming that there exist distinct x, y such that f(x)=x and f(y)=y ?
P.S: Showing uniqueness is simpler than I thought, and I got it too.
1. What is the definition of differentiability of a function?
Differentiability of a function means that the function has a well-defined derivative at every point in its domain. This means that the function is smooth and has no abrupt changes in its slope.
2. How do you determine if a function is differentiable?
A function is differentiable if the limit of the difference quotient exists at every point in its domain. This means that the function must be continuous and have a well-defined derivative at every point in its domain.
3. What is the difference between differentiability and continuity?
Differentiability and continuity are closely related, but they are not the same thing. A function is continuous if it is defined at every point within a certain interval, whereas differentiability requires the function to have a well-defined derivative at every point in its domain.
4. Can a function be continuous but not differentiable?
Yes, a function can be continuous but not differentiable. This can happen when the function has a sharp corner or a cusp at a certain point, which means that the derivative is not defined at that point.
5. What are the applications of differentiability in real-life situations?
Differentiability is an important concept in many fields, including physics, engineering, economics, and statistics. It is used to calculate rates of change, optimize functions, and model real-world systems such as motion, growth, and decay. It also plays a crucial role in the development of mathematical models and algorithms for solving complex problems.
  • Calculus
  • Calculus
