Difficulty following example in Taylor's Classical Mechanics
The discussion focuses on the confusion surrounding the integration process in Taylor's Classical Mechanics, specifically regarding the components of force F. Participants clarify that Fx and Fy represent the components of the force rather than its partial derivatives. It is emphasized that along the path from O to Q, only the x component contributes to work, while the y component does not since it is perpendicular. Conversely, along the path from Q to P, only the y component does work, as the x component remains constant. The key takeaway is the distinction between force components and their contributions to work along specified paths.
cwbullivant
http://i.imgur.com/GP6QorG.jpg
I don't follow the integration in it.
I'm assuming Fx(x,0) and Fy(1,y) are the partial derivatives of F with respect to x and y, respectively, but given that, I can't seem to get my head around the result where the partial with respect to x is Fx = (x, 0) instead of Fx = (0, 2), and similar for y.
They are not the partial derivatives , they are the x and y component of the F force. In the straight path from O to Q its only the x component that does work (y component is always perpendicular). In the path from Q to P its only the y component that does work.
The x component in the path from O to Q is zero because the force is F=(y,2x) so the x component is simply y but y=0 along this path. Similarly the y component from Q to P is simply 2x, but x=1 always for this path so the y component is 2.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
