Diluting the stock solution with ethanol
  • Thread starter Thread starter physicsss
    Ethanol
The discussion focuses on calculating the concentration of a diluted stock solution of sunscreen in ethanol. The initial line provides a concentration of 0.0898 g/mL for the stock solution. The dilution factor is defined as the ratio of the volume of the stock solution to the total volume after dilution. For example, in the second row, the dilution factor is calculated as 2.5 mL (stock) divided by the total volume of 3.0 mL, resulting in a dilution factor of 1:1.2. To find the concentrations for the missing entries (X and Y), one can use the formula V1C1=V2C2, where V1 is the volume of the stock solution, C1 is its concentration, V2 is the total volume, and C2 is the concentration after dilution. By applying this method, the concentrations can be determined based on the known values and the defined dilution factors.
physicsss
mL stock solution___mL95% Ethanol____Dilution factor____g/mL
3.00______________0.00_____________1:1_____________0.0898
2.50______________0.50_____________1:1.2___________X
2.00______________1.00_____________1:1.5___________Y
I think the idea is you are diluting the stock solution with ethanol...how do I calculate how much the concentration is in the solution X and Y?
ignore those lines...I had to use those to line the data up.
Chemistry news on Phys.org
What is the definition of the concentration ? And what does the first line tell you ? And how do you think the dilution factor is defined ?
You ought to show some effort before asking for help, physicsss.
All I'm given is that V1C1=V2C2..., but the volume adds up to 3.0mL. I don't know what the dilution factor means.
Can you write down the question EXACTLY as it appears in your homework/text ?
Okay, that's fine.
Notice that by the definition of dilution factor (volume of stock / total volume), the numbers in the first two colums are consistent with the numbers in the third column.
Example : (row 2) DF = 2.5/(2.5 + 0.5) = 2.5/3 = 1/1.2
In this manner you can calculate the DF for other rows.
The first row tells you the concentration of sunscreen in the stock (.0898 g/mL). Knowing how much sunscreen there is in 1 mL, you can then find out how much there will be in 2.5 mL, 2 mL, 1.5 mL, etc. (the volumes of the different stock solutions). Dividing these weights by the total volume gives you the concentration for each case.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
