Dimensional Analysis: Separating Fact from Fiction
The discussion centers on the validity of dimensionally correct and incorrect equations in physics. Participants debate whether a dimensionally correct equation must be true and whether a dimensionally incorrect equation must be false, ultimately concluding that while some dimensionally correct equations can be incorrect, dimensionally incorrect equations cannot be true. The importance of commensurability in physical quantities is emphasized, highlighting that mixing different dimensions leads to errors. Examples illustrate that dimensionally correct equations can still lack physical validity. The conversation concludes with a consensus on the nuanced understanding of dimensional analysis in physics.
dougr81
I understand the concept of dimensional analysis and what it's used for etc..My question refers to a dimensionally correct or incorrect equation being true or false. Here are the possiblities:
1. A dimensionally correct equation may be correct.
2. A dimensionally incorrect equation may be correct.
3. A dimensionally correct equation must be correct.
4. A dimensionally incorrect equation must be wrong.
5. A dimensionally correct equation may be wrong.
I think all but #3 and #4 are true, but I may be wrong. Any takers?
1 and 5 do not conflict. 2 and 4 do conflict as do 3 and 5. i would disagree with you about 2 and 4. i think 2 is wrong and 4 is correct. so i think that 1, 4, and 5 are correct. 2 and 3 are incorrect.
physical quantities that are added, subtracted, equated, or compared need to be commensurable. if you discover that you are adding apples to oranges, then it's time to stop and look for a previous mistake.
1. True
2. False
3. False
4. True
5. True
4 is true for the same reason that 2 is false. If you have a dimensionally incorrect equation then you are saying at some level that a physical unit equals a pure number. An expression like "1 m = 23.43" is never true.
EDIT: I agree with rbj who was faster on the post!
Thanks for the explanation you two, it makes sense! I thought a dimensionally correct eqn had to be correct but I now see why that's not true. Thanks again!
As an example, one can easily construct equations which are dimensionally correct, but not physically correct, such as
\vec{F} = 2m\vec{a}
\vec{F} = 2m\vec{a}
well, if you define a Newton of force to be the force needed to accelerate 1/2 kg of mass by 1 m/s2, then it would be correct. but it's a dumb definition for the unit force.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
