Dimensionalysis and Conversions
  • Thread starter Thread starter honphysics12
The discussion focuses on determining the dimensional consistency of various formulas using unit conversions. Participants analyze equations involving energy, speed, area, and their relationships to mass, acceleration, and length. The calculations confirm that energy can be expressed as mass multiplied by acceleration and length, resulting in the unit Kg m²/s², which aligns with the standard unit for energy. The conversation emphasizes treating units like numbers during multiplication and squaring dimensions appropriately. Overall, the thread clarifies the process of verifying dimensional consistency in physics equations.
honphysics12
Use the units given in the table below to determine whether the formulas are dimensionally consistent.
/ this symbol (to the left) means divided by
Length= distance= m
mass= Kg
time= s
area= m squared
speed= m/s
acceleration= m/s squared (only the s is squared)
force= Kg m/s squared (only the s is squared)
energy= Kg m squared /s squared
power= Kg m squared /s cubed
How do you solve these and how do you multiply the units?
Does energy= (mass) (acceleration) (length)
Does speed= acceleration/time
Does area= (length) (length)
Does energy= (mass) (speed squared)
Does energy= (mass) (acceleration)/length
I tried the first one.
= [Kg] [m/s squared] [m]
= [Kg m squared /s]
Is that right?
= [Kg m squared /s]
Is that right?
Does that answer match with the unit for energy, which you wrote earlier?
Treat the units as you would ordinary numbers.
So when I multiply the 2 m's and the 2 s's, they become squared right?
The answer would then be Kg m squared /s squared.
Correct.
Right! That's really all there is to it.
