How many dimensions are involved in these sports motions?
  • Thread starter Thread starter Inquiring_Mike
    Dimensions Physics
The discussion focuses on determining the dimensions involved in various sports motions. A motocross racer navigating a hilly track operates in three dimensions due to the terrain's complexity. A curler's stone, while not moving in a straight line, remains on a two-dimensional plane of the ice. A hockey player's puck pass is also primarily in two dimensions, depending on its trajectory. The train traveling on a straight track exemplifies one-dimensional motion, while the conversation hints at the importance of considering time and additional dimensions in sports analysis.
Inquiring_Mike
I've been having trouble with these questions, I would greatly appreciate it if anyone could help to explain them to me.
Question:
Explain how many dimensions the following motion is taking place in.
- a motocross racer rides around a hilly track
- a curler shoots a rock down the ice, around a guard, and onto a button
- a hockey player passes the puck along the ice
- a golfer hits a slice into the woods
- a train travels along a straight section of a track
Anything that occurs on a single straight line is
1 dimensional, anything that occurs in a plane, but not a single straight line is 2 dimensional, any thing that occurs in a volume (not a single plane) is 3 dimensional.
Does the motorcylist ride in a straight line? Does he stay in a plane (on a flat surface)? What dimension are we talking about then?
A curler does not shoot the stone in a straight line (the problem said it goes around a guard) but does stay on the ice. What dimension is that?
A hockey player passes the puck along the ice. That sounds like a single plane. Does the puck curve or change direction?
Do you know what a slice is? That should give you the answer.
A train moving along a STRAIGHT section of track. Well, that was a give-away!
Don't forget the dimension of time (and brane dimensions as well!)
This is the "Grade K-12 Forum", professor!
He could get extra credit... :wink:
(Or lose a mark because the teacher doesn't understand...:frown:)
Thanks everyone for the help!
