Solving Quadratic Diophantine Equations with A=0, C=0
  • Thread starter sparsh12
In summary, a quadratic diophantine equation is a mathematical equation of the form Ax^2 + Bxy + Cy^2 + Dx + Ey + F = 0. When A=0 and C=0, the equation can be simplified to Bxy + Dx + Ey + F = 0. In order to determine if there is an integral solution for this simplified equation, one must ensure that gcd(B,D,E)=1 and use a method that does not involve searching. This can be a challenging task as it may require dividing the problem into cases and checking each one. However, it is possible for circles, parabolas, and hyperbolas to have integer roots.
sparsh12
A quadratic diophantine equation is of form:
Ax^2 + Bxy + Cy^2 +Dx + Ey + F =0
Now, for A=0 and C=0,
Bxy + Dx + Ey + F=0 ...(1)
moreover there is one more condition, gcd(B,D,E)=1
So how do I find if some integral solution of (1) exists or not?
I am not interested in the solution itself, but rather just it's existence.
And the method must not depend on searching, as in the image here:
http://s9.postimage.org/dv30vaixb/diop.png
Original website was:
http://www.alpertron.com.ar/METHODS.HTM#SHyperb
Thanks in advance for advice and ideas.
Why no reply yet?
Well, it's very hard to know what EXACTLY you want, as you say that you want to know about the existence of an integral solution "without searching" (??), but in many instance one HAS to divide the problem in cases and check each, something you apparently don't want to do...
The equation is the standard equation for all conic sections in 2 dimensions. It seems very plausible that there are circles/parabolas/hyperbolas that have integer roots.
I would approach this problem by first understanding the concept of diophantine equations and their solutions. A diophantine equation is an equation where the solutions are required to be integers. In the case of a quadratic diophantine equation, the solutions are required to be integers for both x and y.
In the given equation (1), we can see that A=0 and C=0, which simplifies the equation to Bxy + Dx + Ey + F=0. This means that there is no x^2 or y^2 term in the equation. This also means that the equation is now linear in nature, rather than quadratic. This can provide some insights into the solution of the equation.
The condition gcd(B,D,E)=1 means that the greatest common divisor of the coefficients B, D, and E is 1. This is a crucial condition for the existence of integral solutions. If this condition is not satisfied, it means that there is a common factor among the coefficients, which would result in a fractional or non-integral solution.
Now, to determine the existence of integral solutions, we can use a number of techniques such as the Euclidean algorithm or modular arithmetic. These methods do not involve searching for solutions and are based on mathematical principles and concepts. They can help us determine if a solution exists or not, without actually finding the solution itself.
For example, using the Euclidean algorithm, we can find the greatest common divisor of the coefficients B, D, and E. If this value is not equal to 1, then there are no integral solutions to the equation. On the other hand, if the value is 1, then there exists at least one integral solution.
In conclusion, as a scientist, I would approach this problem by understanding the concept of diophantine equations, using mathematical techniques to determine the existence of integral solutions, and avoiding any searching methods. This approach would ensure a more systematic and rigorous solution to the problem.
1. What is a quadratic Diophantine equation with A=0 and C=0?
A quadratic Diophantine equation with A=0 and C=0 is an equation in the form of ax2 + bx + c = 0, where a and c are both equal to 0. This means that the equation simplifies to bx = 0, which can be easily solved by setting b equal to 0.
2. How do you solve a quadratic Diophantine equation with A=0 and C=0?
To solve a quadratic Diophantine equation with A=0 and C=0, simply set the coefficient of x (b) equal to 0. This results in a solution of x = 0, since any number multiplied by 0 is equal to 0.
3. What is the significance of A=0 and C=0 in a quadratic Diophantine equation?
The values of A and C in a quadratic Diophantine equation determine the shape and position of the graph of the equation. When both A and C are equal to 0, the graph is a straight line passing through the origin. This means that there is only one solution to the equation, which is x = 0.
4. Can a quadratic Diophantine equation with A=0 and C=0 have more than one solution?
No, a quadratic Diophantine equation with A=0 and C=0 can only have one solution, which is x = 0. This is because the equation simplifies to bx = 0, and any number multiplied by 0 is equal to 0. Therefore, there is no other possible value for x that would satisfy the equation.
5. How is solving a quadratic Diophantine equation with A=0 and C=0 useful?
Solving quadratic Diophantine equations with A=0 and C=0 can be useful in finding the solutions to linear equations. By setting the coefficient of x equal to 0, we can easily find the solution to the equation. Additionally, understanding how A and C affect the graph of a quadratic equation can be helpful in visualizing and understanding more complex equations.
  • Linear and Abstract Algebra
  • General Math
  • Differential Equations
