Dirac-Delta Function, Different Integration Variable
The discussion revolves around the properties and implications of the Dirac-delta function and its derivative, particularly in the context of integration with different variables. Participants explore the mathematical relationships and interpretations of integrals involving the Dirac-delta function and its derivative, addressing both theoretical and practical aspects.
  • One participant discusses the integral of the derivative of the Dirac-delta function with respect to a different variable, proposing that it should yield a negative derivative of the function being integrated, but expresses uncertainty about this interpretation.
  • Another participant asserts that the correct relation for the integral of the derivative of the Dirac-delta function is related to the negative derivative of the function evaluated at zero, referencing the distributional derivative definition.
  • Some participants argue that the original formula can be interpreted correctly if the prime notation is understood appropriately, emphasizing the importance of context in interpreting derivatives with multiple variables.
  • Concerns are raised about the validity of integrating the Dirac-delta function or its derivatives without a proper test function, with multiple participants noting that the constant function does not qualify as a test function in this context.
  • One participant suggests that the second expression in the initial post is simply zero due to the properties of the Dirac-delta function, while another agrees but suspects a typo in the expression.
  • There is a discussion about the potential for typos in authoritative texts, with participants referencing a specific book and debating the accuracy of quoted statements regarding the Dirac-delta function.
  • A participant describes a complex scenario involving the insertion of the identity operator in quantum mechanics, expressing confusion about the implications of integrating with respect to different variables and the behavior of the Dirac-delta function in this context.
Participants express differing views on the interpretation of integrals involving the Dirac-delta function and its derivative, with some agreeing on the need for proper test functions while others debate the implications of specific mathematical expressions. The discussion remains unresolved regarding the correctness of certain expressions and the handling of the Dirac-delta function in various contexts.
Participants highlight the importance of specifying the variable with respect to which derivatives are taken, as well as the limitations of integrating distributions without appropriate test functions. The discussion also touches on the nuances of mathematical notation and the potential for misinterpretation.
Ibraheem
Hello,
I know that the derivative of Dirac-delta function (##\delta'(x-x') = \frac{d}{dx} (\delta(x-x')))## does the following:
##\int_{-\infty}^{\infty}\psi(x')*\delta'(x-x') dx' = \frac{d\psi(x)}{dx}##
it is easy to visualize how the delta function and the function ##\psi(x')## interact along the x' axis to give the derivative with respect to x ( i.e scaling ##\psi(x\pm \varepsilon ) ## at each bump ##\pm \varepsilon ##..etc)
However, I am stuck at a situation where
##\int_{-\infty}^{\infty}\psi(x')*\delta'(x-x') dx ##
I am not sure what to do here. But what I think it should equal to is ##\frac{-d\psi(x')}{dx'}## just by applying the same way of thinking as when the integration variable is the same as that of of the function ##\psi##. But here the function I think acts as constant in this integral which makes me doubt my answer. Is this answer correct?
The correct relation is
\int \delta’(x) \psi(x) dx = -\psi’(0).
This follows directly from the distributional derivative definition
f’[\psi] = -f[\psi’].
Well, the original formula was also right, if one interprets the prime in a specific way (it's of course often misleading to use a prime for a derivative when many independent variables are involved). I read the equation as follows:
$$\int_{\mathbb{R}} f(x') \delta'(x-x') = \int_{\mathbb{R}} f(x') \partial_x \delta(x-x') \\
= \int_{\mathbb{R}} f(x') [-\partial_{x'} \delta(x-x')]=+\int_{\mathbb{R}} \mathrm{d} x' f'(x') \delta(x-x')=+f'(x).$$
The 2nd expression in #1 doesn't make sense, because you cannot integrate the ##\delta## distribution or its derivatives without multiplying it with a test function. In the 2nd term, the ##\psi(x')## is just a constant that you can move out of the integral, and then you are left with an undefined integral over ##\delta'##.
You are right. The point is that ##\delta'## is an anti-symmetric distribution, which means that it makes a difference whether one writes ##\delta(x-x')## or ##\delta(x'-x)##. So, this solves the sign issue. I believe the 2nd expression in #1 to be a typo. Regardless, the constant function 1 is sufficiently nice to be able to act on it with the delta distribution and the delta distribution derivative. If one wants to be more stringent, one could look at it as the convolution of two distributions.
You have to be careful with the domain of the distribution. Usually the test-function space is either the Schwartz space of quickly falling ##C^{\infty}(\mathbb{R})## functions (i.e., going to 0 faster than any power for ##|x| \rightarrow \infty##). Then the constant function is not a test function. Usually the integral over a distribution without being multiplied by a proper test function is an undefined expression.
But this was my point. I do not see where the disagreement lies. The exact same definition of the delta distribution works on a set of test-functions that does not necessarily going to zero as ##|x| \to \infty##, in other words it is a distribution on the test functions in ##C^\infty(\mathbb R)## without the additional requirements of being in the Schwartz class. Naturally, the set of distributions on this space is smaller, but the delta distribution does belong to it as well. Furthermore, I did qualify that the given integral could also be interpreted as a convolution of distributions. In that case it should work perfectly well with test functions in the Schwartz class as well.
Ok, if this is the case, the 2nd expression in #1 is simply 0, because
$$\int_{\mathbb{R}} \mathrm{d} x \delta'(x-x')=\int_{\mathbb{R}} \mathrm{d} x \delta(x-x') \mathrm{d}_x 1 =0.$$
That makes also intuitive sense, because you can define the ##\delta## distribution as a weak limit of symmetric analytical test functions and its derivative by the derivative of these test functions.
Sure, I agree with this. This would be the result regardless of which of the possible interpretations you make. Then again, I continue to suspect a typo in the 2nd expression and that the integrand should really contain ##\psi(x)## and not ##\psi(x')##.
So the second equation is wrong. That's odd since this is what Shankar says , at least according to my understanding, in page 64(Principals of Quantum Mechanics)
Did you reproduce the statement exactly as Shankar put it?
Yes.
Than it's a typo in the book.
... and you should not be surprised that books as extensive as Shankar has typos in it ...
I actually think I misquoted him. However in either case, this is what made me look into it. I was trying to insert the identity operator in ##XP|\psi>##, where X and P are the position and momentum operators respectively. I first inserted it between X and ##|\psi>## and I got the following:
##\int_{-\infty}^{\infty}PX|x><x|\psi>dx##
##=\int_{-\infty}^{\infty}x\psi(x)P|x>dx##
Then I again inserted the identity operator between ##\psi(x)## and P and got the following:
##=\int_{-\infty}^{\infty}\int_{-\infty}^{\infty}x\psi(x)|x'><x'|P|x>dx'dx##
so from here I substituted for ##<x'|P|x>## and this is what I got:
##=\int_{-\infty}^{\infty}\int_{-\infty}^{\infty}x\psi(x)|x'>(-i\hbar\delta'(x'-x))dx'dx##
here is where I got stuck. I am not sure if inserting the identity like this is okay. If the integral of the delta function goes to zero then the whole thing goes to zero? which doesn't make sense.I am missing something here. The only way to make sense of it is to integrate first with respect to dx and not dx' in which case I used the following fact that the derivative of the delta function is odd:
##\delta'(x-x')= -\frac{d}{dx}(\delta(x'-x))## so the integral becomes:
##=\int_{-\infty}^{\infty}\int_{-\infty}^{\infty}x\psi(x)|x'>(i\hbar\delta'(x'-x))dxdx'##
which evaluates to :
##-i\hbar \int_{-\infty}^{\infty}\frac{d}{dx}(x'\psi(x')) dx##
which I hope is correct. However I am not sure how will this be if I integrate first with respect to x'.
Well, as I said before, instead of writing a prime just clearly specify with respect to which variable you are taking the derivative. The matrix element of the momentum operator in position representation is
$$\langle x'|\hat{p}|x \rangle=-\mathrm{i} \partial_{x'} \delta(x-x').$$
To prove this, you need
$$u_p(x)=\langle x|p \rangle=\frac{1}{\sqrt{2 \pi}} \exp(\mathrm{i} p x).$$
To prove this you only need the commutator relation
$$[\hat{x},\hat{p}]=\mathrm{i}.$$
To that end define
$$\hat{x}(\xi)=\exp(\mathrm{i} \xi \hat{p}) \hat{x} \exp(-\mathrm{i} \xi \hat{p}).$$
Then you find
$$\mathrm{d}_{\xi} \hat{x}(\xi)=\mathrm{i} \exp(\mathrm{i} \xi \hat{p}) [\hat{p},\hat{x}] \exp(-\mathrm{i} \xi \hat{p})=\mathbb{1}.$$
Integrating this wrt. to ##\xi## again, you get
$$\hat{x}(\xi)=\hat{x} + \xi \mathbb{1}.$$
This implies that
$$|x \rangle=\exp(-\mathrm{i} x \hat{p}) |x=0 \rangle$$
and thus
$$\langle p|x \rangle=\exp(-\mathrm{i} x p) \langle p|x=0 \rangle=N_{p} \exp(-\mathrm{i} x p).$$
To get
$$\langle p'|p \rangle=\delta(p-p'),$$
you have to specify ##N_{p}##. That's easy by inserting a unit operator
$$\langle p'|p \rangle=\int_{\mathbb{R}} \mathrm{d} x \langle p'|x \rangle \langle x|p \rangle=N_{p'} N_{p}^* \int_{\mathbb{R}} \mathrm{d} x \exp[\mathrm{i} x(p-p')]=|N_{p}|^2 2 \pi \delta(p-p'),$$
which implies that (up to an unimportant phase)
$$N_p=\frac{1}{\sqrt{2 \pi}}.$$
Since
$$|x \rangle=\exp(-\mathrm{i} x \hat{p}) |x=0 \rangle,$$
you find
$$\mathrm{d}_x |x \rangle=-\mathrm{i} \hat{p} \exp(-\mathrm{i} x \hat{p}) |x=0 \rangle = -\mathrm{i} \hat{p} |x \rangle,$$
and thus by taking the Hermitean adjoint
$$\mathrm{d}_x \langle x| =+\mathrm{i} \langle x|\hat{p},$$
and thus finally
$$\hat{p} \psi(x)=-\mathrm{i} \, \mathrm{d}_x \langle x|\psi \rangle=-\mathrm{i} \, \mathrm{d}_x \psi(x).$$
  • · Replies 59 ·
  • · Replies 21 ·
  • · Replies 31 ·
