Direction of current in the figure?
The discussion revolves around determining the direction of current through a 7.00-ohm resistor in a circuit with two emf sources. Participants debate whether the current flows up or down through the resistor, with references to the polarity of the batteries influencing the current direction. One contributor suggests applying superposition to analyze the current flow from each battery individually. The consensus leans towards the current flowing down due to the polarity of the batteries, although some express confusion about the reasoning. Ultimately, the discussion emphasizes the importance of correctly interpreting battery polarity in circuit analysis.
ehabmozart
Direction of current in the figure??
What must the emf in the figure be in order for the current through the 7.00-ohm resistor to be 1.76A? Each emf source has negligible internal resistance. Figure
http://i239.photobucket.com/albums/ff92/anakris_24/yf_Figure_26_51.jpg
Kirrchoff's Laws
I know well how to use the laws but my problem here is in determining the direction of current through the 7Ω resistor. Is it up or down and why? ... In the manual it say it goes down due to polarity of the battery.. But it can actually go out of battery 1(left) and battery two?
Try applying superposition. What direction does the current flow through the 7 Ω resistor due to each source when taken individually?
I don't understand your explanation. Even if the current flows out of the 24V battery into the ε battery the top end of the 7R will still be +ve wrt the bottom end.
If ε is +ve then I can't see how the current can ever flow upwards through the 7R.
Edit: It would be bad practice to show ε as -ve with the battery drawn that way around. It would be ok to show a voltage source with the arrow pointing upwards and ε marked as -ve but that's not what you have here.
How about solving it twice. Once assuming the current flow down through the 7R and one assuming it flow up through the 7R. What do you get?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
