Direction of Force (Motor Effect)
  • Thread starter Thread starter n0iz
    Direction Force
The discussion focuses on determining the direction of force on a current-carrying wire in a magnetic field using Fleming's Left Hand Rule. The user successfully identifies the force direction for the first question, concluding it is "out." However, they express confusion regarding the current direction in the second question, noting it appears to flow diagonally down and to the right. Clarification on the current's direction is needed to apply the rule correctly for the second scenario. Understanding the correct application of Fleming's Left Hand Rule is crucial for solving these types of physics problems.
n0iz
[PLAIN]http://img695.imageshack.us/img695/5023/directionofforce.jpg
Basically I have to work out the force acting on a current-carrying wire in a magnetic field.
(http://en.wikipedia.org/wiki/Fleming's_left_hand_rule_for_motors)
Ok so for the first question (the one on the left)
index finger - pointing up
middle finger - pointing right
my thumb was pointing "out"
so the direction of the force acting on the wire was just "out"
For the second question
index finger - up
middle finger - ?
I'm totally stumped on what direction the current is flowing in :(
The current in the second picture appears to be flowing diagonally down and to the right.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
