Direction of magentic field with two wires?
The discussion focuses on determining the direction of the magnetic field at point P, where two wires carrying currents intersect at right angles. The magnetic field generated by each wire is influenced by both the current magnitude and the distance from the point of interest. It is clarified that the direction of the net magnetic field at point P will be determined by the wire producing the stronger magnetic field, which is not solely based on current but also on distance from the point. The relationship between current and magnetic field strength is emphasized, noting that it is proportional to the current and inversely proportional to the distance. Understanding these principles is crucial for accurately predicting the magnetic field direction in similar problems.
fm621
direction of magentic field with two wires??
Two long, straight wires cross each other at right angles. Find the direction and magnitude of the magnetic field at point P, which is in the same plane as the two wires
Bnet = B1 - B2
B= U0I/2pir
I've figured out how to get the magnitude, my question is about the direction. Which way would the magnetic field point? I have two rods, rod1 is in the positive Y-Direction and carries a current of 6.00A and rod2 carries a current in the positive X-Direction.
7A rod has a magnetic field that is coming out of the page, and 6A rod has a magnetic field going into the page. Point P is at (4.00, 3.00)m
Would the magnetic field at Point P be coming out of the page because the rod with the larger current triumphs?
Bnet could also be B1 + B2 depending on the quadrant you're in. Is there any more problem info? Given the B1-B2 case, the direction of the field will be based on which term is larger, simple as that. The larger term could be larger either due to distance or current.
It would be in quadrant 1. So if I come across this problem on a test then I can assume that whichever B is larger then that's the direction the magnetic filed will take at a point?
Even in quadrant 1, the field will depend on the direction of each of the currents.
Yes the field with the larger magnitude at point P will give you the direction of the magnetic field. But what you can't do, as you've done above, is assume that the larger current makes the larger magnetic field. Thats only true on the line y=x, where the point is equidistant from each wire. Each B is proportional to I and inversely proportional to r.
