Calculate Time for Discharging Capacitors
  • Thread starter Thread starter Rupturez
    Capacitors
The discussion centers on calculating the time it takes for a capacitor to discharge to a practical zero voltage. The equation for instantaneous voltage during discharge is provided, but the challenge arises when trying to determine the time for complete discharge, as it leads to an undefined answer when substituting zero volts. Participants clarify that due to the nature of exponential decay, a capacitor never truly reaches zero volts in finite time. Instead, they suggest defining a "practical" voltage level, such as 5% or 1% of the initial voltage, and using the time constant formula to estimate the discharge time. Ultimately, the conversation emphasizes the importance of setting a practical threshold for voltage when calculating discharge time.
Rupturez
Hi there,
okay my Question is on discharging capacitors.
the equation for instantanious voltage of a capacitor whilst dischargeing is : v=Vi*e^-t/R*C
However I am not sure how to find the time for a capacitor to completely discharge to zero volts.
When I transpose for t
t=-(R*C)*ln(v/Vi)
and input v as zero (cap has completely discharge) we get an undefined answear.
I havnt studied calculus and am not familiar with the concept of limits.
how would I go about finding the precise time for a capacitor to discharge without using a normalised universal time constant curve to estimate the answear.
thanks in advance
Of course you get a dippy answer. With exponential processes, you Never get to zero. Each interval of RC seconds, the volts decrease by 1/e. You can't get to zero without an infinite value for the time.
Of course, 'as near zero as dammit' would take a very finite time! (Engineer speaking)
I understand the voltage will never actually reach absolute zero, however I am after the "practicle" time for the capacitor to reach "practicle" zero voltage.
First decide on what is an acceptably low voltage for your purpose and then put it in your formula.
Hi Ruptures. As sophiecentaur has pointed out, it is the nature of the (negative) exponential function that it never reaches precisely zero in any finite time. A "practical" time depends upon just how close to zero you consider "practically zero", but two common choices are
- 5%, which takes almost exactly 3 time constants, and
- 1%, which takes approximately 5 times constants.
Ahh 5 time constants that rings a bell. thanks uart
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
