Can Quantum Mechanics Allow for Discontinuous Wavefunctions and Probabilities?
  • Thread starter Thread starter Loren Booda
    Wavefunction
Loren Booda
Quantum mechanics requires continuity of the wavefunction and its first derivative. How stringent is this requirement? If general relativity allows singularities, why not have possible discontinuity of a single wavefunction and its derivative?
Take [psi]1(x)=cos(x) and [psi]2(x)=-cos(x). Although themselves and their derivatives respectively discontinuous, these wavefunctions define a continuous probability, |[psi]1(x)|2=|[psi]2(x)|2.
What of discontinuos quantum probability itself? Take a probability step function of finite domain, discrete at x=0. If we can say that an event occurs with probability P for -[ee]<x<0, what can we say about a probability P' for -[ee]<x<[ee]? It seems to me that this singular step makes undefinable probability P' in terms of P.
discontinuity of the wave function.
First of all, it is funny you consider cos(x) as being a discontinuous function . But ok, apart from that, the continuity constraints on the wave function psi come essentially from the condition that it has to obey the Schroedinger equation, which is second order in x. In order for the second order derivative to be finite (even if discontinuous), the first order derivative and the function itself should be continuous. If you allow for infinite potentials (such as a hard wall), then the second order derivative should also become infinite, hence only the function itself should be continuous, but it is clear that this is an idealisation in the model.
cheers,
patrick.
vanesch,
"respectively discontinuous." Just graph them together - at no value of x are cos(x) and -cos(x) in continuous agreement, or are their derivatives.
Ah... I suppose you're talking about a function, f(x), such that:
f(x) = cos(x) if x<y
f(x) = - cos(x) if x > y
for some y.
Sorry, the expression "respectively discontinuous" was a bit weird to me, but I guess you meant the above.
f(x) won't be the solution to any "reasonable" Schroedinger equation. I say, "reasonable" because you could think of a highly singular potential function which doesn't represent a physical situation for which this could be heuristically true (with derivatives of Dirac impulses).
The probability is not the only physical content of the wave function. The phase is just as important, and in the classical limit, the phase corresponds to Hamilton's principal function (in Hamilton-Jacobi theory in classical mechanics). So it is not because the probability seems to make sense that any underlying complex function makes sense as a quantum wave function.
cheers,
Patrick.
But this does not mean that the wave function cannot be discontinuous at the initial time t=0, right? So if at t=0 a wavefunction is discontinuous at a point, doesn't that go against the probabilistic interpretation? I mean, probability of finding a particle at that point would be undefined.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
