Discover the Best Truss Design to Support Your Fascia | Expert Tips
  • Thread starter Thread starter HarryKoh
    Support Truss
The discussion revolves around the design of a truss intended to support a fascia that is positioned at a height of 3 meters, raising concerns about its stability. Participants are exploring how to calculate the adequacy of the truss for this purpose, with a focus on structural design principles and engineering considerations.
  • Homework-related
  • One participant inquires about the calculations needed to determine if the proposed truss can adequately support the fascia.
  • Another participant expresses that there is insufficient information provided, questioning whether the structure is a building and suggesting that a structural engineer's approval may be necessary.
  • A later reply confirms that the structure is part of a university capstone design project.
  • Another participant critiques the initial design of the support structure, suggesting that it is inadequate and encourages a reevaluation of the design process by identifying loading forces and optimal fixing points.
  • This participant also recommends using free body diagrams as a method for analyzing the structural system.
Participants do not reach a consensus on the adequacy of the truss design, with some expressing concerns about the initial proposal and others suggesting improvements. The discussion remains unresolved regarding the best approach to support the fascia.
Limitations include a lack of detailed information about the loading forces and structural requirements, as well as the absence of specific calculations or design parameters that could clarify the discussion.
HarryKoh
Hey guys, from the figure, I was planning to put a truss (shaded in the figure) to support the fascia, due to the fascia being too high (3m) and it may be unstable, thus adding the additional truss support. But my question is how do I calculate if that shaded truss is enough to support the fascia? Any idea guys? Thanks.
P/S : Could've add a tie to the fascia, but I really do want to know if the truss can support the fascia..
Thanks and best regards.
Not enough information given. Is this a building? If yes I'm guessing a structural engineer must approve the design unless you live in a country where anything goes?
Yep, it is a building, but a capstone design project in my university.
That is not a very good design of support structure with or without the extra strut .
See if you can come up with a much better one .
Start the design process by identifying the magnitude and direction of the loading forces acting on the facia and marking them on a scale diagram of the facia and building wall .
When you have done that work out the simplest system of structural members that will carry these loading forces back to the fixing points on the wall . Decide for yourself where the optimal positions for these fixing points are .
This design process is essentially similar to use of free body diagrams for solving simple textbook statics problems .
21K
  • · Replies 16 ·
