Discover the Most Reactive Element with Chlorine - Francium Revealed
  • Thread starter Thread starter ritwik06
The discussion revolves around identifying the element that reacts most violently with chlorine, specifically focusing on Francium and its comparison with other elements like Cesium and Hydrogen. Participants explore the definitions of "violent" reactions and the implications of electronegativity and ionization energy in determining reactivity. The conversation includes theoretical considerations and practical limitations regarding the handling of Francium.
  • One participant suggests Francium as the most reactive element with chlorine, seeking validation of this claim.
  • Another participant questions the definition of "most violently," proposing that the rate of reaction and the amount of heat produced could be factors in determining violence.
  • Some participants argue that while Francium is theoretically more reactive due to its low ionization energy, Cesium may actually react more violently based on available data regarding ionization energies.
  • A later reply notes that practical considerations limit the ability to react Francium with chlorine, as it is rarely found in weighable quantities.
  • Discussion includes a side topic on neutralizing chlorine spills, with suggestions of using Magnesium or Calcium as safer alternatives compared to alkali metals.
  • Participants emphasize the need to define "violent" in the context of chemical reactions, with some suggesting that reaction speed and surface area of the reacting metals are important factors.
Participants do not reach a consensus on which element reacts most violently with chlorine. Multiple competing views remain regarding the definitions and implications of reactivity, particularly between Francium and Cesium.
Limitations include the uncertainty surrounding the practical reactivity of Francium due to its rarity and the varying definitions of "violent" reactions. The discussion also highlights discrepancies in ionization energy values from different sources.
ritwik06
Name the element which reacts most violently with Chlorine.
My answer: Francium
Please tell me if I am right or wrong?
Thanks a lot in advance! :redface:
I would tend to agree with you based on the electronegativity scale. A nagging question is, "What is meant by 'most violently'?" Most heat produced? Quickest reaction? It seems to me that chlorine (gas) reacting with a solid will be limited in its rate (violence?) by the surface area of the solid. A gas can be made to react almost instantaneously with another gas, so my choice for 'violence' would be hydrogen + chlorine.
See here:
http://jchemed.chem.wisc.edu/jcesoft/cca/CCA1/R1MAIN/CD1R1380.HTM
See here:
Well, I agree, but violence here, I think would be rated in the terms of energy liberated. So does my answer fits with this definition of violence?
Your answer is fairly close. The most electropositive stable element is Cesium, however. The longest lived radioisotope of Francium has a half life of 21.8 minutes. At any given time on the crust of earth, there exists less than an ounce of Francium. No weighable quantity of Francium has ever been prepared or isolated on Earth. Its ionization energy is actually slightly higher than that for Cesium which implies that it is slightly less electropositive than Cesium. All of its chemical properties have been derived from radiochemical methods so the accuracy of these values might not be as high as for more stable elements.
Define violent.
I would guess Francium though aswell.
Neutralizing Chlorine that has poisoned the ground
In regards to Neutralizing Chlorine, if liquid chlorine has been spilled into the ground, is there any way to neutralize it that will not hurt or add any additional trauma to plants and/or animals?
producerii
Chemistree is correct, that there is no practical way to react a sizeable quantity of Francium with Chlorine. Theoretically Francium SHOULD produce a more 'violent' reaction, as most texts I've seen state that "the lowest 1st ionization energy in the alkali metals is Francium". However, every reputable source that gives an ACTUAL ionization energy shows Cesium as slightly lower: (375.7 kJ Mol-1 vs Francium's 380 kJ Mol-1)
Since most sources list Fr and Cs as having equal electronegativity, I would tend to agree that Cesium would actually react more violently with chlorine (although this goes against periodic trend).
(and just so people don't ask, We can ignore differences in electron affinity because the Alkali metal is giving up its electron, not gaining one)
as for the totally off topic hijack question of "neutralizing" chlorine, I havn't looked anything up but off the top of my head I'd say Magnesium or Calcium, they're far less dangerous on their own than Alkali metals, each mole of them will theoretically bond with two moles of chlorine, and both products Magnesium Chloride and Calcium Chloride are harmless salts. But for all practical purposes, you're probably better off just heavily dilluting the area with water.
Offtopic Answer
Most chlorine scrubbers consist of an aqueous NaOH solution. The chlorine dissolves in the solution and you get hypochlorite (bleach).
Chlorine has a boiling point of around -34 deg C so unless you tipped over a dewar in the arctic it will vaporize. Due to the density of chlorine (and volume of gas if it was initially a liquid) the chlorine gas will probably lurk around for a little while but eventually go away, and if I were you I'd get far far away while that happens.
As Tim09 said - define violent.
I will add one thing here. The faster the reaction, the more violent it is (most likely, may depend on the 'violent' definition). The more atoms of metal at the surface, the faster the reaction is. But there is less francium atoms per surface unit then cesium atoms - so if there are no other differences (electronegativity, electron affinity/ionisation), cesium reaction can be faster!
  • · Replies 46 ·
  • · Replies 20 ·
36K
