Discrete Math - question about sets
XodoX
1. Homework Statement
Use set builder notation to give a description of each of these sets.
a) { 0,3,6,9,12 }
b) { -3, -2, -1,0, 1, 2, 3 }
c) { m,n,o,p }
3. The Attempt at a Solution
X={x l x is an odd possitive multiplier of 3 less than 12 }
X is supposed to be the set. Can I just name it randomly? Also, can I say it like this? Is that ok? Not really sure about b and c.
You can name your set what you like.
For b, notice the elements are integers from -3 to 3; that is, x\inZ AND -3 \leq x \leq 3
For a, x does not have to be odd since 6 and 12 are in the set. You are right that they are positive multiples of 3 and less than 12 but can you describe that in mathematical notation?
Oh yeah.. nevermind. They are not all odd.
And no, I don't know. I'd just simply say : X= { x\inZ l x is positive x*3 less than 13 }
If you denote 3Z as the set multiples of three, then the set in (a) consists of elements x \in3Z such that 0 \leq x \leq 12
Alternatively, if you've seen quantifiers before you can write the set as
\left\{0,3,6,9,12\right\} = \left\{ x \in \mathbb{Z} \mid \exists y \in \mathbb{Z} \left(x=3y\right), 0 \leq x \leq 12 \right\}.
The first predicate essentially says that x is included in the set if and only if there exists an integer y such that x is three times y.
For example, the number 4 would not be included in the set because there is no integer that satisfies 4=3y. If you haven't seen quantifiers yet, then nevermind. :smile:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
