Discrete Probability: Mean Number of Red Bulb Non-Failure Cycles
The discussion revolves around calculating the mean number of cycles of non-failure operation for a red bulb in a traffic signal system that cycles through amber, red, and green lights. Participants explore the probabilities of bulb failures and the implications of those failures on the operation of the traffic signal. There is uncertainty about whether the traffic signal continues to function with failed bulbs or stops altogether, which influences the probability distribution used for calculations. The probability of the red bulb operating for n cycles without failure is expressed as P(No Fail)^n = (1-pR)n, leading to the expectation E(N)=Σ(n*(1-pR)n). Clarifications regarding the operational behavior of the signal upon bulb failure are deemed necessary for accurate calculations.
Astudious
A traffic signal operates in the following cyclic regime: amber (A) light for 5 seconds,
then red (R) for 30 seconds, then amber again for 5 seconds, then green (G) for 40 seconds
(thus making a cycle ARAG), and then in the cyclic manner, i.e. ARAGARAG... .
Let us assume that the amber, green and red bulbs can fail every time they switch on
with independent probabilities pA, pG and pR, respectively.
What is the mean number of cycles of non-failure operation of the red bulb?
I suppose the E(X)=Σ(x*P(X=x)) over all valid x is probably relevant here.
The probability that the bulb operates for n cycles without failure is P(No Fail)^n = (1-pR)n. So then E(N)=Σ(n*(1-pR)n) where n is summed from 0 to infinity perhaps? But I wouldn't be able to reduce this (and from the solution, it isn't right anyway ...)
Please clarify: what happens when a colored bulb fails? Does the unit continue to function--but using only the other, non-failed bulbs--or does it stop functioning altogether when any of its bulbs fails? If it does continue to operate, does it just "by-pass" the failed bulb, or does it still occupy the time of the failed bulb, but without light? For example, if the first Amber fails (but the unit keeps operating) does that collapse to a RAGRAG... situation with each cycle shortened by the missing 5 seconds, or does it remain at BRAGBRAG..., where now B = blank (lasting 5 sec)?
I believe there is only one Amber bulb.
I read the question as referring to cycles of the red bulb, so at this stage what the other bulbs are doing is irrelevant. I assume this is one part of a multipart question. Astudious, can you confirm that?
Yes.
Yes, but that is without stipulating what happens next. I.e. it's probability of at least n cycles without failure...
... but here you have used it as though it is the prob of exactly n cycles.
Astudious said:
Yes.
OK, but my original question still stands. I can see two possible scenarios:
(1) The unit keeps functioning until all its lights fail, in which case the distribution of the number of cycles until red fails will be given by some probability distribution A.
(2) The unit functions only as long as none of the lights have failed, and in that case the distribution of the number of cycles until red fails (if ever) is some other probability distribution, B. (In that case, "red fails" = "red no longer shines" = "anything fails".)
My guess is that he/she means (1), but asking for clarification does no harm.
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
