Disk on a Motion: Find the Coordinates of Point A at t= 4piR/v
  • Thread starter Thread starter BBAI BBAI
    Disk Motion
To find the coordinates of Point A on a disk after a specified time, the initial conditions include a radius R, an initial velocity v in the positive x-direction, and an angular velocity ω equal to v/2R. The motion of Point A can be expressed as a function of the center's velocity and ω. The discussion emphasizes the need to relate the motion of Point A to these variables for accurate calculations. Participants suggest starting with ω to simplify the problem. The goal is to derive the correct coordinates of Point A at t = 4piR/v.
BBAI BBAI
Adisk of radius R centred at the origin is placed on a frictionless x-y plane with origin as the centre of the disk.At t=0, the disk is given initial motion such that the point A(R,0) has velocity v towards
+ve x-axis and ω=v/2R. Find the coordinates of Point A at t= 4piR/v
∅=ωt..That's all i think is needed
i used but i am getting a wrong answer help!
Can you express the motion of A as functtion of the velocity of the center and ω?
Based on that, can you calculate this velocity and ω?
That's the problem..The velocity of A at t=0 is given..How can i relate to the centre of mass velocity..
I proposed to start with the other direction (use w,ω for the center and calculate the motion of A as function of those variables) for a good reason - it is easier.
Did you try to calculate it?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
