Dispersion of light in a prism confusing
The discussion centers on the confusion regarding the refractive indices of red and blue light in a prism. It is clarified that blue light has a higher refractive index than red light, which is contrary to the initial assumption that red light would refract more than blue. The relationship between wavelength and refractive index is explained, noting that as wavelength increases (frequency decreases), the refractive index decreases. The Cauchy dispersion formula is suggested for better understanding of this relationship. Ultimately, the original assumption about the positioning of red and blue light within the prism is incorrect, as blue light bends more due to its higher refractive index.
Nanyang
I understand that as the frequency of an electromagnetic wave increases, its refractive index decreases in a material. According to this, red light would have a higher refractive index than blue light (is my mistake here? why?).
Since sinI/sinR = n (where I is the angle of incidence, R is the angle of refraction, n is the refractive index), and if I is a constant, for red light R would be smaller than that in blue light.
If so, then when a beam of white light shines into an upright triangular prism, inside the prism the red light should be 'below' the blue light.
But this is contrary to the picture depicted here: http://en.wikipedia.org/wiki/File:Dispersion_prism.jpg"
Where is my fault? :confused:
Science news on Phys.org
Blue light has the greater refractive index and I suspect you are getting frequency mixed up with wavelength in your first sentence.Try googling the Cauchy dispersion formula for greater clarification
So then there is a mistake in this MIT ocw material http://ocw.mit.edu/NR/rdonlyres/Physics/8-02Electricity-and-MagnetismSpring2002/BB80210A-AC60-443D-9DF2-3E3658AE6812/0/speedlight.pdf" ?
I clicked but couldn't get into it because of compatibility issues.To a fairly good first approximation the refractive index of glass varies with wavelength in accordance with the following equation:
n=A+B/W^2 ... A and B are constants and W=wavelength.As you can see as W increases(f decreases) n decreases
That link is probably correct. However, if you look at the refractive index for visible wavelengths (0.4 - 0.7 μm), it does decrease as the wavelength gets longer:
http://refractiveindex.info/figures/figures_RI/LIQUIDS_Water_20.0C.png
Refractive index of waterhttp://upload.wikimedia.org/wikipedia/en/2/20/Dispersion-curve.png
Refractive index of several glass types
