Dispersion Relation KdV equation
3 replies · 18K views · last reply
hanson
Hi all.
I have some questions about the dispersion relation in the study of waves.
First of all, why do we always assume a plane wave solution when we want to obtain a dispersion relation?
Second, is "assuming a plane wave solution" a general way to obtian all dispersion relations? for both linear and nonlinear wave equations? So, what is the dispersion relation for the KdV equation? I can hardly see anyone deriving the dispersio relation for nonlinear equations like KdV and NLS etc, why?
Try this link for excerpts from "Oscillations and Waves"
http://books.google.com/books?id=ge...6VB&sig=pDI-xn5gOrVd_qmFKMPIsIl3xEA#PPA413,M1
I think we tend to start with the simplest form for the mathematical description of a physical phenonmenon and work up to more complex situations.
Working in one dimension is simple compared to two or more, and where possible, one would prefer a linear system to a nonlinear one.
Solutions to 'idealized' models are a first step before introducing more complex and difficult structures.
First, concerning LINEAR diff.eqs:
A typical feature of the solutions to these is that the SUM of two solutions is ALSO a solution.
Furthermore, it is generally true that ALL solutions of a given diff.eq can be regarded as generated by a sum of base solutions.
This is what is called the superposition principle, and it is immensely important in all of physics.
However, with NON-linear diff.eqs, the superposition principle does not in general hold, i.e it is NOT normally true that the sum of two solutions is also a solutions, nor can we assume there exists a set of basis solutions out of which we can generate all solutions.
But that means, esssentially, that for the non-linear case, "every particular problem has its own solution", rather than this solution being derivable from solution to other problem.
The problem with non-linear diff.eqs is that neither the solutions methods nor the solutions themselves for a particular problem has any generalizable value.
Plane wave solutions are handy to work with since they of course are plane, hence if the wave is progressing in one direction, for example parallel to an x-axis, then for every point on x the wave motion can be described by a single number denoting the amplitude in the entire yz-plane. Now all periodic functions and following all waves can be described by a Fourier transform which in essence is a long combination of plane waves weighted by a coefficient function. Therefore the dispersion relation can be found by considering the plane component waves of this Fourier transform.
For a linear equation all component waves will be independent of each other due to the superposition principle and therefore it is relatively easy to find the dispersion realtion. For non-linear equation like the KdV the superposition principle does not apply and there is mixing between the different component plane waves. This makes it difficult to determine a exact dispersion relation.
An approximation to the dispersion relation can be deduced by inserting a plane wave solution in the linearized version( just dropping the non-linear term) and this yields:
w(k)=ck-ek^3
where c denotes the coefficient before the term involving the first derivative with respect to x and e is the coefficient of the dispersive term.
