Displacement after Time T in a Velocity Field
1 reply · 3K views · last reply
Teg Veece
I have a velocity field that is static in time. At every location, x, there is a corresponding velocity vector.
I'm trying to work out the displacement of a particle after T seconds if I drop it into the velocity field at time t=0 and at location x_0.
I was thinking something along the lines of ∫v(x_0)dt between the limits of t=0 and t=T but it doesn't seem right because the integrand doesn't seem to depend on t at all (in fact v(x_0) is a constant so it can't be right). Maybe there's a double integral involved...
Anyone know what a suitable form for this equation would be?
For simplicity, you could consider a one dimensional case:
[itex]\frac{dx}{dt}=v(x)[/itex]
This is a separable differential equation, so:
[itex]\int_{x_0}^{x_f}\frac{dx}{v(x)}=\int_0^T dt[/itex]
But it gets you a solution for the final time, T.
[itex]T = \int_{x_0}^{x_f}\frac{dx}{v(x)}[/itex]
If for a fixed x0, you can suppose that the total time is a function of the ending position.
[itex]T = f(x_f)[/itex], where this function is given by the right hand side of the equation above.
So, to get the ending position for a given total time, you would need to take the inverse of that function
[itex]x_f = f^{-1}(T)[/itex]
In order to get a closed form for this, you need to plug in the velocity field. I don't think there's a way to get a general expression for an arbitrary velocity function.
Now, for a two dimensional problem you need to do this for each component of the position vector.
