- 23,756
- 5,961
One of your previous responses was closest to the correct answer (#12).
Chet
Chet
Chestermiller said:One of your previous responses was closest to the correct answer (#12).
Chet
physicsnobrain said:Ok, well then this has to be the right answer.
No. It should essentially be exactly the same as #12, but with a vertical line coming up from the final point at the right-side, up to the t axis.physicsnobrain said:Ok. But at the end it accelerates slow then quickly accelerates. So should it be this?
Chestermiller said:No. It should essentially be exactly the same as #12, but with a vertical line coming up from the final point at the right-side, up to the t axis.
You are allowed to say that only once!physicsnobrain said:Ok, well then this has to be the right answer.
NascentOxygen said:You are allowed to say that only once!
Yes, that's about as correct as you are going to manage here. It should sync with the distance vs time graph, so that corresponding times line up. The original distance vs time graph has 3 intervals of roughly equal duration. (That final vertical line is debatable, where you mis-sketched the distance vs time graph.)
I told you this was right quite a few posts back, before you spun off into wild guesses! http://physicsforums.bernhardtmediall.netdna-cdn.com/images/icons/icon6.gif
Now for your acceleration vs time graph ...
It might do that, then again it might not. It's difficult to judge from a small sketch. It certainly is not sufficiently obvious that I would agree to it being drawn that way. Neither can I say that the acceleration is fixed and constant here. So the best you can do, without more precise data, is to come up with a rough sketch of what you estimate is happening.physicsnobrain said:Ok. But at the end it accelerates slow then quickly accelerates
I'd give you 4 out of 5 for that.physicsnobrain said:Ok. So here is the acceleration chart I'm getting off of the velocity chart. Looks good?
NascentOxygen said:I'd give you 4 out of 5 for that.
During the object's travel, there is a moment which could be described as <CRUNCH!>. Where is this point, and how would it show up on the acceleration vs time plot?
I'd leave out that right hand side vertical line. It's doubtful.
NascentOxygen said:Your answer is not clear.
If you were that object, at what point(s) in time would you be most likely to suffer bruising? Can you put yourself into that scenario?
Explain why.physicsnobrain said:probably at the very end when the graph ends.
NascentOxygen said:Explain why.
A sudden change in acceleration would not cause discomfort. If you were to step out off a ledge your vertical acceleration would change very quickly from 0 to g, but you would feel no shock. There are two points in the trajectory where something does change suddenly from nonzero to zero, and that would cause a shock. What is that something? If the change were really to take no time at all, what would the acceleration be?physicsnobrain said:The object instantly goes from having acceleration then goes to 0 acceleration instantly.
haruspex said:A sudden change in acceleration would not cause discomfort. If you were to step out off a ledge your vertical acceleration would change very quickly from 0 to g, but you would feel no shock. There are two points in the trajectory where something does change suddenly from nonzero to zero, and that would cause a shock. What is that something? If the change were really to take no time at all, what would the acceleration be?
Except you told me that we don't know what happens there, where I circled at the right. The recording stops as soon as the object passes through zero displacement. We don't know whether it smoothly continues on to a negative displacement or whether it halts at zero (you drew it showing that it stops at zero, but then clarified that you did that in error). So the end of the graph is an unknown; we definitely cannot say there is a bruising crunch there.physicsnobrain said:The object instantly goes from having acceleration then goes to 0 acceleration instantly.
Yes, there is a sudden change of speed there. So how to improve your acceleration vs time graph to show this happening?Is it when the object moves up, then proceeds to stop moving up instantly?
NascentOxygen said:EDIT: Ah, I see you answered already:
physicsnobrain said:I'm just not seeing it. When I separate this graph into three distinct segments ( reflective of the three in the displacement time graph) this graph seems to make perfect sense to me:
Yes. I tried various scenarios, including a sticky tennis ball, wet washing, and a spit ball (bogan kids at school would chew up paper and flick a ball of it onto the classroom ceiling!) That dwell time is important.Also, would a good scenario be similar to the one you said previously, but instead of a t-shirt, a wet toilet paper ball is thrown to the ceiling, sticks to the ceiling for a few seconds, then falls back down?
NascentOxygen said:Okay. Stop right there. Here's an exam question: an object with some initial upward velocity is subjected to the acceleration you show in your graph. Sketch the expected velocity vs time graph.
Now, your graph for the above?
If the velocity changes from a nonzero value to zero in an extremely short time, how great is the acceleration?physicsnobrain said:The acceleration time graph I made just seems to work for this, I honestly can't figure out the change:
haruspex said:If the velocity changes from a nonzero value to zero in an extremely short time, how great is the acceleration?
