Display Problem in MicroStar Motherboard Based P.C.
  • Thread starter Thread starter rahulkhajuria
The user is experiencing display issues on a system with an MS-7101 v2.0 M-ATX motherboard and a Pentium 4 Dual Core CPU, where the screen shows multicolored blocks and the PC hangs. After resetting the BIOS to default settings, the problem persisted until a change was made to the "Assign IRQ for VGA" setting, which resolved the multicolor issue but left the text slightly faded. The user is running Windows XP SP2 and suspects a display driver issue. Recommendations include uninstalling the current display driver to revert to the default VGA driver, updating the display driver from the manufacturer’s website, and updating DirectX. The user plans to continue researching BIOS settings and will keep the community updated on the situation.
rahulkhajuria
I have a MS-7101 v2.0(865G/GVM3-V) M-ATX mainboard with a Pentium 4 Dual Core CPU based system . RAM is 512 MB (DDR) . However , sometime after I have switched on the P.C. , the screen (display) suddenly starts going bad . pink ,blue ,green & red blocks start appearing on the screen & within seconds the P.C. hangs . Recently I had set all the BIOS settings to Default . I think some setting needs to be changed here . Could you help , please ?
Computer science news on Phys.org
I'm not sure this will solve the problem, but it might be that your display driver is causing problems. What operating system are you running?
I would uninstall the display driver, which will cause the default VGA driver to be used. If that resolves your problems with the screen colors, you can then reinstall the display driver you were using. Better yet, go to the Web site of the manufacturer of you display adapter, and see if there is an updated display driver you can download.
Agreed, sounds like a driver issue to me. You should also update direct X.
I'm running Win Xp Sp2 . The issue seems solved as of now (after a minor setting that I changed in the BIOS) . The settings in the BIOS which I think are related to Display are as follows :
(The x sign in front of an option is the current selection - after I reset the BIOS Settings to Default Factory Settings )
I Under STANDARD CMOS FEATURES :
Video EGA/VGA x
CGA 40
CGA 80
Mono
II Under ADVANCED CHIPSET FEATURES :
Memory Hole at 15M - 16M Disabled x
Enabled
Init Display First Onboard x
PCI Slot
On Chip VGA Enabled x
Disabled
On Chip Frame Buffer Size 1 MB
8 MB x
16 MB
III UNDER PnP/PCI CONFIGURATION :
Assign IRQ for VGA Enabled
Disabled x
I have again experimented with the last setting , namely "Assign IRQ for VGA" (changed it to "disabled" , the factory default was "enabled" ) , and after this change , the multicolor blocks don't come on the screen anymore . However, the letters seem slightly faded & I guess I'll try with your suggestion about the Device Driver . Meanwhile , tried contacting the Motherboard Company but they haven't given any satisfactory answer . Will try & research through Google if I need to change any more BIOS settings as well . Will try & keep you updated on the issue .
In my discussions elsewhere, I've noticed a lot of disagreement regarding AI. A question that comes up is, "Is AI hype?" Unfortunately, when this question is asked, the one asking, as far as I can tell, may mean one of three things which can lead to lots of confusion. I'll list them out now for clarity. 1. Can AI do everything a human can do and how close are we to that? 2. Are corporations and governments using the promise of AI to gain more power for themselves? 3. Are AI and transhumans...
Sorry if 'Profile Badge' is not the correct term. I have an MS 365 subscription and I've noticed on my Word documents the small circle with my initials in it is sometimes different in colour document to document (it's the circle at the top right of the doc, that, when you hover over it it tells you you're signed in; if you click on it you get a bit more info). Last night I had four docs with a red circle, one with blue. When I closed the blue and opened it again it was red. Today I have 3...
