What Happens to Polysaccharides Like Hemicellulose When Dissolved in Water?
  • Thread starter Thread starter Baho Ilok
    organic chemistry
Polysaccharide dissolution in solvents, particularly water, primarily involves the breaking of hydrogen bonds between macromolecules while maintaining the integrity of glycosidic bonds. This means that the polymeric structure remains intact, and individual monomers do not typically dissolve in the solution. Glycosidic bonds are resistant to hydrolysis under normal conditions, such as room temperature and neutral pH. The discussion specifically addresses the behavior of hemicellulose xylan when dissolved in water, confirming that it retains its polymeric form rather than breaking down into monomers.
Baho Ilok
I would like to understand more about the mechanism of polysaccharide dissolution in a solvent that which it is soluble in. Do they maintain polymeric structure (glycosidic bonds) and only lose side-chain bonding (H-bond) among each other? Or are will their glycosidic bonds be compromised resulting in individual monomers dissolving in the solution?
Or does this question even make sense? The real reason why I asked this question is that I just want to know what form the hemicellulose xylan takes when dissolved in water.
Thanks!
Chemistry news on Phys.org
Usually dissolving polysacharides in water will only break hydrogen-bonding between macromolecules. The glycosidic bonds should be maintained intact. These bonds are fairly resistant to hydrolysis at room temperature and neutral pH.
Likes Baho Ilok
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
