Distance between current-carrying loops
  • Thread starter Thread starter Brainy_Mike
    Loops
When two identical loops of transformer wire carry current in the same direction, they generate a uniform magnetic field at the midpoint between them only when the distance between the loops equals the radius of each coil. This uniformity occurs because the magnetic fields from both loops reinforce each other at that specific distance. If the loops are closer together, the magnetic fields do not combine uniformly, leading to variations in the field strength. The discussion clarifies the definition of "uniform" as consistent magnetic field strength across multiple points. Understanding the geometry and spacing of the loops is crucial for achieving the desired magnetic field characteristics.
Brainy_Mike
If I generate current through two identical loops (parallel) of transformer wire in the same direction, why do they produce an uniform magnetic field at the centre of the space between the loops ONLY IF the separation distance between the loops is equal to the radius of each coil? and not if they are closer?
Thanks
What do you mean by the "centre of the space between the loops"? Are you referring to a plane that is equidistant from the plane of each loop? Or are you referring to the axis between the centres of the two loops?
AM
the midpoint on the axis through the centres of the two loops
That is a point. What do you mean by 'uniform'? Uniform means the same over a number of points.
AM
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
