Distance between two complex numbers
The discussion focuses on the calculation of the distance between two complex numbers represented as vectors on an Argand diagram. The user seeks confirmation on their notation and understanding, particularly regarding the relationship between vectors and their magnitudes. It is clarified that while vector PQ equals z(2) - z(1), the magnitude of vector PQ is represented as |z(2) - z(1)|, emphasizing that a vector and its magnitude are distinct concepts. The distinction between vectors and their magnitudes is reinforced, highlighting that one is a geometric entity while the other is a numerical value. Understanding these differences is crucial for accurate representation in complex number calculations.
naav
Hi...i was wondering if someone could confirm if what i have below is correct...thanks...sorry i can't present a diagram...
z(1) = x + iy and z(2) = x(2) + iy(2) are represented by the vectors OP and OQ on an argand diagram...(O is the origin)...imagine the argand diagram...the upper left hand quadrant...(OQ has an argument of say 30 degrees and OP has an argument of 45 degrees - these pieces of information are not relevant anyway)...
is the following correct...
vector OP + vector PQ = vector OQ...
then vector PQ = vector OQ - vector OP
then vector PQ = |z(2) - z(1)|...
1. was wondering if my notation and understanding here is correct...i used algebra in the second line so i was wondering if that is legit...?...
2. is it correct to say in the last line the vector = the magnitude
Mathematics news on Phys.org
That's fine.
That's wrong. You should have:
\vec{PQ} = z_2 - z_1
|\vec{PQ}| = |z_2 - z_1|
Or, in plain text:
vector PQ = z(2) - z(1)
|vector PQ| = |z(2) - z(1)|
Hi...thank you very much...
i said in my earlier post...
and it was said that it should be...
1. isn't that the same thing...
that vector PQ = the magnitude of [z(2) - z(1)]...?...
No, it is not the same thing: |vector PQ| is a number (the length of the vector PQ), not a vector.
Likewise "vector PQ" is a vector while "the magnitude of [z(2)-z(1)]" is a number.
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
