Distance & Direction City A to City C - Vector Question HELP
  • Thread starter Thread starter parwana
    Vector
An airplane travels 200 km due west from city A to city B, then 305 km at an angle of 34.0° north of west to city C. To find the straight-line distance from city A to city C, one must calculate the vector components and apply the cosine rule. The angle between the two legs of the journey is crucial for determining the direction of city C relative to city A. The discussion emphasizes the importance of correctly identifying vector components and using trigonometric principles to solve the problem. Understanding these concepts is essential for accurately determining both the distance and direction from city A to city C.
parwana
An airplane flies 200 km due west from city A to city B and then 305 km in the direction of 34.0° north of west from city B to city C.
(a) In straight-line distance, how far is city C from city A?
(b) Relative to city A, in what direction is city C?
for a can't u do a^2 + b^2= c^2?
I tried doing that and it doesn't work, help
or is it 305- 200??
for b I don't know what to do?
or is it 305- 200??
For A, you need to find a vector that points from city A to city C, let's call it \vec V_{AC}. If you find the magnitude of this vectors (| \vec V_{AC} |) that gives you the length of the vector (ie the straight line distance from A to C.
What would subtracting 305-200 give you?
Instead you need to subtract the components individually.
For B,
I'm not really sure what they are asking. You'll have to wait for someone else to help you. I could guess, but I don't want to confuse the situation.
how do I find magnitude?
Lets say you have a vector \vec v = \hat i(1) + \hat j(2)
I don't know what notation you use to represent components.
The modulus (magnitude) of the vector is |\vec v| = \sqrt{1^2 + 2^2}
Or in general,
\vec A = (x,y)
| \vec A | = \sqrt{x^2 + y^2}
Did you try drawing the diagram out?
C is 34.0 degrees north of west, so that means C is on a bearing of (270 + 34) from B.
Now you've got 305km and 200km and the angle in between in, which "entitles" you to use the cosine rule.
So for part A,
CA^2 = AC^2 + AB^2 - 2(AB)(AC)cos(ABC)
and for part B, they want you to find the angle CAB, and write it in the form eg. 34.0 degrees north of west from xxx.
using the sine rule and the result of part A, i.e CA,
(sin ABC)/CA = (sin CAB)/CB
angle CAB = sin inverse ((BCsinABC)/CA)
therefore, C is XXX degrees north of west from A.
whats AC? in the equation natarae? and what's the value of ABC when u do cos ABC. Sorry I am really bad with physics
I believe AC is the line between points A and C. Thats one leg of the triangle ABC.
yeah but I am not given AC?
AC was what you figured out in part A.
And to figure out angle ABC you could draw a straight line with another line coming off of it at a 34 degree angle. So what do you get for angle ABC? What you get for that you can plug into the equations that natarae gave you because then you'll have CA and angle ABC.
Is that what you were asking?
But I didnt figure out part A yet. Arent I trying to find AC in part A itself?
I am very confused by this, please help
Well I want to know if natarae might have made a mistake in his equation to figure out AC
But I think the AC^2 and the AC are meant to be BC^2 and BC respectively, which would make it possible to find AC.
I see, that's what I was getting confused on
now I understand, but still what's angle ABC. Wouldnt it just be 34?
Well since the line is 34 degrees north of west, I believe you would have to look at the line like this ___34_\________ so you would have to figure out the supplementary angle, and that would be angle ABC
Oh I see I drew it wrong, in the other direction, so it would be 146
thank u so so much royalewith. I understand
One last question, why do we use cosine instead of sine for the angle?
Because we are using an adjacent leg and the hypoenuse, so according to my favorite math acronym...or whatever its called:
SOHCAHTOA
We are using A and H so we would use cos.
thank u so much
[spam]
No problem, glad to help...now if only I could figure out my own physics :smile:
[/spam]
