Calculating Distance from Model Rocket Photo
  • Thread starter Thread starter KevinMWHM
To calculate the distance of a model rocket from a photo taken at its peak, one can use the known length of the rocket and its magnification. By photographing the rocket alongside an object of known distance and measuring the pixel size in the image, the distance to the rocket can be determined. The formula to use is: distance to the rocket equals known distance multiplied by the ratio of the unknown size to the known size. This method allows for accurate distance estimation based on image analysis. Understanding magnification is crucial for precise calculations.
KevinMWHM
Launched a model rocket with my 5 & 3 year old, have a photo of the rocket straight overhead at the approx peak. Can I figure out the distance? I know the length, and the magnification. What would the formula be?
Mathematics news on Phys.org
Depends what you mean by the magnification.
But if you photograph the same object a known distance away and note how many pixels it is on the image then you can work out the distance to the rocket by just comparing the number of pixel on your photo.
So distance rocket = known distance * unknown size/known size
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
