Distance light travels in a relatively moving frame?
  • Thread starter Thread starter Reikoku
    Frame Light
Reikoku
I was wondering if say.. you have a particle moving at 0.5c in the +x direction and a lightbulb at relative rest to the particle.
The particle passes the lightbulb at t_{0}
The lightbulb then flashes, the wave reaches the particle at a particular point, and the speed of light is then measured (by the particle) to be c. Does this then mean that the light wave will then travel a distance of ct from that point in the reference frame of the particle; t being any point in time that the particle wishes to measure the distance of the light wave from it.
If the particle and lightbulb are at relative rest, how can they pass each other?
Oh am I using the wrong terminology? I meant to say that the particle is moving with 0.5c compared to the lightbulb.
OK.
Yes.
Thanks Doc Al, that's helped clear up confusion.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
