Distance travelled by the particle
  • Thread starter Thread starter utkarshakash
    Particle
A constant power P is applied to a particle of mass m, and the distance traveled when its velocity increases from v1 to v2 is under discussion. The initial attempt at a solution led to an incorrect formula for distance, while the correct answer provided in the textbook is m(v2^3-v1^3)/3P. A suggestion was made to verify the formulas using numerical values to check for consistency and correctness. By calculating the initial and final kinetic energies and using the power rate, one can determine the time taken and subsequently the distance covered. This approach may clarify the discrepancies between the two formulas.
utkarshakash
A constant power P is applied to a particle of mass m. The distance traveled by the particle when its velocity increases from v1 to v2 is(neglect friction)
Work done = ΔKE
P=dW/dt
s=(v2^2-v1^2)/2a
Since work done by all forces equals ΔKE
Work done = m(v2^2-v1^2)/2
Now P=dW/dt,
differentiating W wrt to t, I get
a=P/m(v2-v1)
Putting a in last equation I get
s=m(v2^2-v1^2)(v2-v1)/2P
but this answer is wrong :(
The correct answer given in my book is m(v2^3-v1^3)/3P
I don't know where I've commited the mistake.
Work done = ΔKE
P=dW/dt
s=(v2^2-v1^2)/2a
Now P=dW/dt,
a=P/m(v2-v1)
Being a cynic about answers like this given in texts, I would consider an equivalent problem with numerical values and check that the "formula" answer does give the correct answer. Perhaps your answer does also, and there is just 2 ways of saying the same thing.
Use values that should not give a coincidental answer ie avoid a value of 2, since 2 + 2 and 2 x 2 give the same answer.
EG 14 kg mass traveling at 7 m/s, is accelerated to 11 m/s when power is added at the rate of 5 watts. How far would be covered.
Your formula says 14(121 - 49)/10
Their Formla says 14(1331 - 343)/15
They are not the same answer, so at least one of them is wrong.
Hint: find the initial and final Kinetic energies. Since the energy was added at a rate of 5 J/s, you can work out how long in time that takes.
Since the average speed is 9m/s, you can thus calculate the distance covered.
While doing that numerical calculation, you may even see why your/their answer will be correct.
Good luck.
Note: You could repeat the calculation for some different values, to show your agreement was not coincidental.
