How Does the 12% Efficiency Factor Influence Theoretical Yield in Distillation?
  • Thread starter Thread starter demode
    Distillation Lab
The discussion revolves around calculating the theoretical yield of ethanol from a sucrose solution in a distillation lab, considering that only 12% of the sucrose is converted to ethanol. The balanced equation provided indicates that 49.36 g of sucrose can theoretically yield 26.99 g of ethanol. However, the 12% efficiency factor must be applied to adjust this yield, as it reflects the maximum conversion limit due to yeast toxicity at higher ethanol concentrations. The conversation highlights the importance of the initial sugar concentration and the volume of water used in determining the final yield. Understanding these factors is crucial for accurately reporting the theoretical yield in the lab report.
demode
Hey everybody, I just completed a small distillation lab for my high school chemistry class. We took a sucrose/water solution, added yeast to ferment it, and distilled it into ethanol for about an hour in the lab.
I'm trying to write my lab report, and I've hit a huge stumbling block! One of the questions asks to determine the theoretical yield using the balanced equation we had to come up with, but it also says keep in mind that only 12% of the sucrose will be converted to ethanol Does this 12% factor into anything! Heres my work:
C12H22O11 -> 4C2H5OH + 4CO2
We used 49.36 g of sucrose in the original solution FYI
(49.36 g) * (1 mol sucrose/342.34g) * (4 mol ethanol / 1 mol sucrose) * (46.08 g / 1 mol ethanol) -> 26.99 g ethanol
Do I do anything with that 12% or is that my theoretical yield right there!?
I'm not sure you read something correctly. Or I don't understand what you said.
Saccaromyces cerevisae (yeast) can convert sugar (fructose, sucrose) into ethanol.
When the concentration of ethanol gets to about 12% in the medium, the yeast shuts off
alcohol production. It sort of "toxifies" itself, so to speak.
All this presumes that you used brewer's yeast. Other yeasts may not fare as well.
In other words - alcohol percent depends on the starting concentration of sugar and the maximum possible concentration based on the volume of water left, of ethanol. For example, you start with 20% sucrose solution, then yeast will shut off before using up all of the sucrose.
You never stated the volume of water used - or I can't find it...
Is that what you are after...?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
