DIY - Replacing my bicycle tire with recycled plastic
The discussion revolves around the DIY project of replacing a bicycle tire with a solid tire made from recycled plastic. Participants explore various methods, materials, and challenges associated with this unconventional approach, including previous attempts with cement and the selection of appropriate plastic types.
  • One participant proposes creating a solid tire from recycled plastic using a homemade mold made from cardboard and cement.
  • Another participant suggests filling the tire tube with solid material, sharing their own attempt to use cement, which ultimately failed due to clogging issues.
  • Concerns are raised about the selection of recycled plastic, with one participant emphasizing the need for durability and a suitable melting point.
  • Some participants question the feasibility of using cement for tire construction, arguing that pliability is essential for effective tire performance.
  • One participant mentions the potential use of construction foam as an alternative filling material, though they express skepticism about its long-term effectiveness.
  • A later reply discusses the decision to create a mold from another tire, indicating a shift in approach based on earlier suggestions.
  • Another participant shares their experience purchasing quality tires, highlighting the benefits of low weight and performance, contrasting with the DIY efforts.
Participants express a range of views, with some supporting the idea of using recycled plastic while others doubt its feasibility. There is no consensus on the best approach, and multiple competing ideas remain throughout the discussion.
Participants note limitations in their approaches, including issues with mold construction, material selection, and the challenges of achieving a functional tire. The discussion reflects a variety of assumptions about material properties and construction techniques.
Individuals interested in DIY projects, sustainable materials, or alternative bicycle tire solutions may find this discussion relevant.
Evanish
So the rubber on one of my bicycle tires has worn out to the point it needs to be replaced, and I was thinking I'd prefer a solid tire this time. Rather then buying one like a normal person I was thinking if I could make my own out of recycled plastic.
Here is the plan as it currently stands. Get some cardboard and cut a hole for the spokes so the tire can be level with the board. Get some more cardboard to form a ring so I have a crude mold to melt the plastic into. then glue all this together so it won't move around while I'm working. Here is a picture of the crude mold I'm thinking about making to form my plastic wheel.
KM4TVswDWAumGOTKfl-WZNZeO9i0vF6SEZL_EOGyT_RRPCS46csOrPXOTvlBUUibANERTPGnyVeBxutB2NxfV6MiX952pqcU24vO-81yFHSj7bawfYb7nsvmpergqZjT5gioWi8tj3nbR2fiskVCrS6iwTY7tyErQd8U3Frrw65-2JgVNml1FVR_boupsmQwH0apihPAM-qEJFAHyt9KuuOePmBinRdT4s8dWgi6pznJor8Hd92u8rrDIOPxCwMBWxEcU_0-UesN67rzXOHCRCugBRx4FNLXEp__Mo229W65gX7XVqAOLSPYWTWgS9uNbeaLJH2SpVLtUXX13U00jf-3PE2qYW4Ojcb2ul3fXFfmHcluyAkbfwNZoNprytjXkry2c1iZeEZvMbGwUbWUTFgiuab0-pQs6p4Oi37djunfRT30_DtjLp1Hxd7Cc5PhCXMl5UahZbK1U6mIT8PTLFaLGPsZfvKFYJOb2G8KCOcvv-L-06zlssqIBuX5YAUAMQKcSvuS9T6cRwUcmIqp0nhtf9gl2uJkBXiaFsEc49T0N5vj9gQyqhMHamRCoSkfWHwwKDxsz-xeIzxpXgzZ3HU9H76mmNcD6bwPBow=w473-h352-no
Next I'd melt little pieces of plastic into the mold with a 14 amp heat gun.
Z6xI80RzAtDGXvWQbNE-3WgDQxAtEqCDCDuCAn-aUB9mZQYBwhCaa7bH9dIQurqIGb1sW9A8xg=w327-h244-no.png
Then I'd remove the newly formed tire from the mold. I assume that it won't be formed well enough at this point to make for a good ride. In order to fix this I though about using a lath, but the tire is too big. Then I though about reattaching it to the bicycle and using lath tools on it there. Here is a picture of the tools in question.
jtlnkvc8Aen96asEscVUTTp3sPnWd-5p8OEL00DeE1LlC8Ag-VD4aUATEJR4KOL5RuwUj5y6OMkds_SNnI=w1131-h637-no.jpg
In order for this to work I think I'd need to find some way to use an electric motor to spin the wheel. I have a motor I took form a blender that I'm hoping to use. Here is a picture.
0P8H5MXNQlWxb-SN1HBTARGuqRJWEIsyICshi5ThCf1039O5iktPsKOnwnMVsV3kwccvze_cYQpKmQbfEY=w1131-h637-no.jpg
Of course I'll be careful about the exposed wires. I was thinking I could attach a wheel to it, and then put that wheel in contact with the bicycle wheel in order to spin it using friction.
One big issue is this idea is finding some way to secure everything in the correct position while I'm working. I have some clamps, twist ties and other simple restraint for that, but I'm feeling that trying to find something to attach everything to and getting everything lined up would be very frustrating.
Frankly I'm not really feeling confident about the project as a whole so I thought I'd post it here and see what people think. Any suggestion on the project would be appreciated.
  • Z6xI80RzAtDGXvWQbNE-3WgDQxAtEqCDCDuCAn-aUB9mZQYBwhCaa7bH9dIQurqIGb1sW9A8xg=w327-h244-no.png
  • jtlnkvc8Aen96asEscVUTTp3sPnWd-5p8OEL00DeE1LlC8Ag-VD4aUATEJR4KOL5RuwUj5y6OMkds_SNnI=w1131-h637-no.jpg
  • 0P8H5MXNQlWxb-SN1HBTARGuqRJWEIsyICshi5ThCf1039O5iktPsKOnwnMVsV3kwccvze_cYQpKmQbfEY=w1131-h637-no.jpg
Why not just fill the tire tube with solid material?
I actually attempted filling the tire tube with something. After considering various options I decided to try filling the tire with cement. I purchased some masonry cement and put it through a strainer to get out the bigger rocks. Then I cut short the bicycle tire air valve so that I would have an unimpeded hole to squirt the concrete into it. Then I bought one of the bellow from dollar tree to use as a pump to get the cement into the tube.
b_ZK0snPxVXtY9laNFfQutshIz7Y2M3_mwBpklRX1-DdXfE_GMRL-u5Fb7HO2VT4QWpr7-LcCdlfrWOlXxk=w192-h436-no.png
I cut of the upper end so that the plunger could be removed, and the cement funneled in. Unfortunately at some point before I could get started someone mistook my pump for trash, and threw it away. Feeling frustrated I decided to use a bit of scrap PVC pipe and wooden doweling in it's place. This turned out to be a mistake as sand from the cement got jammed between the wooden doweling and the PVC pipe leading to the plan's failure. The only thing I succeed in was clogging the air valve with cement leading me to need to switch to this new plan. Perhaps it would have failed anyways as I had added quite a bit of water to the cement to get it flow smoothly so it was really weak when it dried and so I may have ended up with lumpy tires as result.
  • b_ZK0snPxVXtY9laNFfQutshIz7Y2M3_mwBpklRX1-DdXfE_GMRL-u5Fb7HO2VT4QWpr7-LcCdlfrWOlXxk=w192-h436-no.png
Selection of the recycled plastic would be critical. It needs to be not brittle, yet durable, and with a melting point compatible with your heart gun. How are you selecting the plastic?
Could you use another tire to make a mold, then use something like lost wax casting?
I was thinking of using LDPE. The melting point is pretty low at 180-240 centigrade. I tried melting plastic bags with the heat gun, and it seems to work well enough so LDPE should be good. It's also not brittle. As for durability it will hopefully be good enough. Also, I picked up a big LDPE kids sand box someone was getting ride of so I should have enough material. I'm guessing they put something in it to protect against UV light which is also a plus.
As for using another tire to make a mold I'll have to think about that a bit. I can't use a big mold where the plastic enters in from a single point because melted plastic doesn't flow very well. From what I've read in the plastic industry they use high pressures injected into steel molds to get around this, but that isn't an option for me. Maybe I can make a half mold of a good tire with concrete though. That might be more effective then the crude mold I talked about above.
In truth, I think this is an effort in futility. You must know you need something as pliable as rubber.
Using cement doesn’t make sense.
Have you researched solid tire construction?
The cement thing is very likely a bad idea as even if I succeed in getting it in the resulting tire would likely be less than ideal. My hope was that the tuber tube, and old tire would, would encase the cement in such a way that even if it broke into many pieces the tire would still be fairly firm, but I've given up on this idea now. I've also heard about people using construction foam to fill their tires, but from what I've found on it the results weren't that great either as the foams used tend to collapse over time. As for my plastic idea I'm not too confident on it either. If I was a more practical person I'd have long sense given up and just bought a pre made solid bicycle tire of the correct size. Even though I'm low on funds it's bound to be a lot cheaper, easier and more effective then what I can do DIY wise. At any rate perhaps out of stubbornness, or just to see if I can pull it of, I'm incline to preserve a little while longer.
At any rate here is a fun video of a Russian man filling his tire with concrete, and another where he replaces it with a log.
The results are less then ideal.
I spent 75 dollars for 3 Continetal 700x25mm 120psi tires. They are a good compomise of low weight and good wear characteristics. The low spinning weight helps improve my preformace. Quality tires reduce my risk of of injury.
My memory is bad, checked the order, 3 tires were less then 50 bucks with free shipping.
So here is an update. I decided to make mold the other tire like anorlunda suggested. I decided to make it out of masonry cement since I had some, and I thought would be sturdy enough. To start with I prepared some ground to work on. Here is a picture of the ground I leveled and the whole I made for the spokes.
JoGOo0OU5yZo_nIT46blU6_Vs1uixKKhFTbdyHC-RFLNpWZdd4kYlmbb1-IKWi2nBsh7NKVKDRfqFL8umw=w1131-h637-no.jpg
Next I put down the cement (about 11 pounds dry), put the tire one it, stepped on the tire to make it sink in and then shaped the cement around the tire by hand. Here is a picture of the result.
oZ-1V4yjdrM-Fhcg1kdwil159m2h2qcc3XjuLg6BUi9U4eSWnwubFMg_eEbwsuUFc27gdhDjkf2NUX0oas=w1131-h637-no.jpg
The next day I made a mistake by trying to remove the tire too soon, and ended up breaking the mold before it hardened. After waiting for things to harden fulled I glued the mold back together with super glue, used some more cement to fill in the missing pieces and then enforced it with even more cement. At any rate, I'm waiting for things to harden now. I'll be back with more updates as things progress.
  • JoGOo0OU5yZo_nIT46blU6_Vs1uixKKhFTbdyHC-RFLNpWZdd4kYlmbb1-IKWi2nBsh7NKVKDRfqFL8umw=w1131-h637-no.jpg
  • oZ-1V4yjdrM-Fhcg1kdwil159m2h2qcc3XjuLg6BUi9U4eSWnwubFMg_eEbwsuUFc27gdhDjkf2NUX0oas=w1131-h637-no.jpg
I have to say you have the mind of a classic inventor. There’s a movie you should watch
The Worlds Fastest Indian
Its a story about an eccentric inventor living in Australia who keeps tinkering with his old Indian motorcycle with the hope of someday racing it at the Bonneville Salt Flats.
He had the mind of a classic inventor who attacked engineering problems in ways no engineer ever would. One example was how he made his high speed tires by using a paring knife to remove the tread.
Anthony Hopkins stars as the inventor.
Bert Munro was a Kiwi (New Zealander). I don't believe he ever lived in Australia. He changed his first name from Bert to Burt after it was mispelled in a motorcycle magazine.
  • · Replies 20 ·
  • · Replies 31 ·
  • · Replies 21 ·
  • · Replies 0 ·
