Do Atoms Exist in a Perfect Vacuum?
  • Level: High School
  • Thread starter santhony
    Atoms Vacuum
80 replies · 19K views · last reply
But, in a solid, aren't the atoms bonded together?
The atom nuclei don't touch. The electrons can be shared though.
So, between the subatomic particles exists empty space?
I'm not the person to discuss this with as I know very little about it. This subject should perhaps be the subject of a separate thread as you'll get a far better scope for responses.
The nucleus is about 1 billionth the size of the whole atom I believe. Between the nucleus and the electrons is effectively empty space.
Well, seeing an atom or anything, for that matter, could not be logically held together by a vacuum, it would seem the definition for "vacuum" is merely a product of arbitration.
Atoms aren't held together by a vacuum. In fact, I don't think anything is 'held together' because of a vacuum.
Again, a vacuum is an area that has as little matter in as possible.
A perfect vacuum has no matter in it what-so-ever.
I don't see what's arbitrary about that. And the make up of an atom certainly has no bearing on it.
It is my understanding, and maybe I'm wrong, that, between the nucleus of an atom and its electrons exists a "vacuum", as it's defined.
When a specified volume contains no matter, it is considered a perfect vacuum. So any volume, regardless of size - whether between two electrons or two planets - devoid of matter is considered a vacuum.
This has absolutely nothing to do with what binds the atom together.
The definition of a vacuum is simply an area with no matter in it.
In current theories, elementary particles are point(!) particles (contrasting with string theory in which they are 1-D strings). Meaning they take up no space at all, and, so if you want to go to those scales, I guess you could say everything is a vacuum. But the sense of a vacuum sort of loses its meaning at those scales.
These "singularities" introduces problems (e.g. infinite energy is required to compress a charge e into a point), which is beyond my realm of knowledge (something to do with renormalization).
Usually we say "vacuum" in a macroscopic way.
I agree, that is the physical definition of a "vacuum". But, being void of matter doesn't mean being void of everything. The point, that, I was trying to make was, if you were to ask the average person on the street to define a "vacuum", for the most part, it would be defined as empty space or space containing nothing.
Never said it was. That isn't the purpose of the word vacuum.
Vacuum only deals with matter - I'm sick of saying this now.
All well and good, but this has no bearing on the scientifically accepted definition. The 'people on the street' are wrong on a lot of things, it doesn't make what they believe to be true correct in any way.
You've jumped from atoms to people on the street. Do you have a question you need answering or are we just going to traverse the entire field of physics discussing random matters of the vacuum?
I'm not even going to begin to say, I know much about physics. Just, that, I have an interest in learning. So, please, excuse my ignorance. If elementary particles take up no space, seeing all matter is made of elementary particles, wouldn't it go to reason, we would take up no space, either? In other words, no matter how many times you add up zero, it still equals zero.
Please, let's not go down this route.
Suffice to say, no it does not mean that.
Code:
For one thing I don't believe my question is straying away from my original topic of a vacuum. I believe it's going to the very heart of it. Sorry, but I find it hard to except something just because an authority says it's so, especially if it doesn't seem to be consistent, and hopefully you have a healthy dose of skepticism, yourself. Science was never meant to be a religion, and I would appreciate it if you would not treat as such. You are under no obligation to answer my question. And, apparently the fact that it is not an irrational question is betrayed by the fact that you have said, "I'm sick of saying this now."
Science is not a religion. No one is treating it as such.
The "authority" on this matter is science, worldwide science and the associated scientists - not the people on the street. There is absolutely no debate on what a vacuum consists of and the definition is consistent wherever you see it.
Vacuum has a scientifically accepted definition. That's the end of it.
Every dictionary has the same definition of a vacuum - what the people think is irrelevant. If the people don't understand a word then that is their problem. It doesn't make their use correct.
I'm sick of giving the definition. It isn't going to change and there's no debate on that matter. Vacuum describes an area with no matter in it.
I only brought up my point to try to get you to steer away from trying to consider length scales that are much smaller than the nucleus of an atom when considering the word "vacuum". Vacuum is operationally defined as a region of space that is devoid of matter. If we start looking too close at distance scales on par with the sizes of the particles which make up "matter", the word "vacuum" begins to lose it's meaning. In those scales, perhaps the word "space" is better.
P.S. No it doesn't mean macroscopic objects, which are made of many particles, take up no space. Even though the elementary particles have no finite spatial extent, we still have distances between these elementary particles, which has a meaning.
If there was a perfect vacuum, what effects would have? and would these change something in science?
Given how close space is to a perfect vacuum (~1 hydrogen per metre cubed) it really wouldn't make much difference.
There would be no changes to science and no "effects".
Thanks to everyone who contributed to answering my question, "Do atoms exist in a vacuum?" I can see, now, using the standard definition of "vacuum", that, they do exist. In fact, they are in more places than I previously imagined.
However, my last question, for future reference, is, does a word exist that explains a space free of everything, including energy?
Note, atoms do exist in all vacuums because we can't get a perfect vacuum.
A perfect vacuum however contains no atoms.
Not as far as I'm aware.
