Do Identical Cans with Different Colors Reach the Same Water Temperature?
  • Thread starter Thread starter SciencePF
    Temperature
In an experiment with two identical cans, one black and one white, filled with equal masses of water and exposed to the same power of radiation, the water temperatures will not reach the same level. The black can absorbs more heat due to its color, leading to a higher temperature than the white can. This difference in absorption suggests that the initial temperature of the water in both cans may not have been the same. Even after sufficient time, the black can's water could reach a temperature of 50 ºC while the white can's water may not reach that temperature under identical conditions. Therefore, the color of the can significantly affects the final water temperature.
SciencePF
Suppose the following experience:
Two identical cans one black and one white with equal mass of water inside.
We focus radiation at the same power on each.
After enough time, that we want, do the water will reach the same temperature in both cans?
If not, can we conclude that the water was at different temperatures in the cans at the beginning of the experiment?
Science news on Phys.org
Please explain what you mean by this.
Suppose that the water in the black can goes to 50 ºC. Is it possible that the water in the white can goes to 50ºC, if we gave it enough time, maintaining same initial conditions?
