Do light and sound waves roll up and break like ocean waves?
The discussion explores whether light and sound waves exhibit behaviors similar to ocean waves, particularly the phenomenon of rolling up and breaking as they approach a boundary or medium change. Participants examine the theoretical implications and analogies between these types of waves, focusing on their properties and behaviors in different contexts.
  • Some participants describe how ocean waves break due to varying velocities of water layers as they approach the shore, questioning if light and sound waves experience similar phenomena.
  • One participant suggests that sound waves might exhibit a collapse similar to a sonic boom when an aircraft breaks the sound barrier, while light behaves differently due to its constant speed.
  • Another participant proposes that breaking waves could represent a transition from transverse to longitudinal waves, citing examples from electromagnetic waves and sound waves.
  • Discussion includes the concept of Cherenkov radiation, where particles exceed the speed of light in a medium, raising questions about light's behavior in different media.
  • Some participants note the compressibility of water compared to air, suggesting this affects how waves behave in these media.
  • One participant highlights the differences between surface waves and other wave types, emphasizing the unique characteristics of ocean waves involving both transverse and longitudinal displacements.
  • Concerns are raised about the necessity of a force field, such as gravity, for wave breaking to occur, questioning if similar effects could happen near a black hole.
  • Several participants discuss the role of turbulence and the conditions necessary for wave breaking, suggesting that overtaking of wave parts is essential for such phenomena.
The discussion remains unresolved, with multiple competing views on whether light and sound waves can be analogized to ocean waves in terms of breaking and rolling up. Participants express differing opinions on the conditions required for such phenomena to occur.
Participants mention various assumptions regarding wave behavior, including the need for a force field for wave breaking and the role of compressibility in different media. There are also unresolved mathematical and conceptual steps regarding the transition between wave types.
  • #31
nikkkom said:
Google NWFAQ. A very good read on shocks.
I 'Googled' and got a vast list of hits. If you could be a bit more specific then I could perhaps read what you are referring to.
Science news on Phys.org
  • #32
tech99 said:
The heads of the waves stand up out of shelter and are pushed by the wind.
Under some circumstances, yes but you do not need much wind at all for a wave to break. The wind can even be offshore. The effect of breaking is more to do with the bottom section slowing down than the top section accelerating.
  • #33
Computational texts will do it far more justice than I can, but, to use my own term, differentition is 'flaky' with regard to the step-sized used. See attached images:
It is common for textbooks (especially old ones like Computational Physics by Koonin and Meredith from ~1970 and before symbolic computing from which the images are from) to highly discourage computational differentiation if possible.
Let me know if it is still unclear and I can maybe find a better explanation from text.
  • #34
Those numbers really don't help me at all. A bit of context about shock waves would be appropriate.
  • #35
The behavior of the error (going from positive to negative is of interest here. Also the error for integration converges to 0 for much larger values of h).
This is a mild digression from shockwaves, but in direct reply to OP's statement in the quoted post.
  • #36
Which quoted post? You started off by quoting My Post, about shock waves being local but I was not the OP.
It would really help if you were a bit more fulsome with your writing. That last post still means very little to me (or many other readers, I fear).
Whilst you may know everything there is to know about this topic, if you want your ideas to be taken in by the readers of the thread, you need to help us a bit. We may not actually be thinking along your lines until you give more guidance.
  • #37
The post I quoted in my initial comment. Specifically, comment #15 in the thread.
The reason I am not being completely fulsome is because it is a digression from the topic and one OP may not even be interested in.
Exerts from Computational Physics, Koonin and Meredith for context:
  • #38
I really would appreciate you telling us how that apparently random cut and paste is relevant, either to the OP or to the topic of shock waves. Do you genuinely believe that it is a sequiter to any of the preceding posts?
Post #15 introduced Black Holes. Is that the link?
It's several months before April 1st.
  • #39
It is directly relevant to the sentence quoted in my first post, as I have mentioned before. I genuinely can't clarify any more than that. I have also twice clarified it as a digression, yet you persisted I expand further. I genuinely don't know what more you want.
  • #40
Perhaps if you posted this as a new thread in the Mathematics Forum it may make more sense to more people.
  • #41
K.
  • #43
nikkkom said:
It took a bit of searching to find this section:
3.6.1.1.1 Free Surface Release Waves in Gases
Let us assume that material supporting the shock wave is a gas. Since the pressure change in a rarefaction wave is always continuous (no instantaneous pressure drops), the pressure at the leading edge of the escaping gas is zero (in keeping with the requirement of equal pressures at the gas/vacuum interface) and the process of converting internal energy into kinetic energy is complete. The front edge thus immediately accelerates to the final maximum velocity (escape velocity) when it reaches the free surface. Farther back in the release wave the pressure increases and the velocity decreases. At the release wave boundary (which moves backward at c_s) the pressure and velocities are the same as in the original shock wave.
The escape velocity of a gas is equal to:
Eq. 3.6.1.1.1-1
u_escape = (2*c_s)/(gamma - 1)If we use a frame of reference in which the unshocked gas was stationary we get:
Eq. 3.6.1.1.1-2
u_escape = (2*c_s)/(gamma - 1) + u_particleand the rear edge of the release wave travels backwards at
Eq. 3.6.1.1.1-3
v_release = u_particle - c_sThe release wave thus stretches itself out with time at a speed of:
Eq. 3.6.1.1.1-4
((2/(gamma - 1)) + 1)*c_swhich for a perfect monatomic gas is 4*c_s.
It contradicts the concept of sound waves crashing summed in one sentence, "Since the pressure change in a rarefaction wave is always continuous (no instantaneous pressure drops), the pressure at the leading edge of the escaping gas is zero (in keeping with the requirement of equal pressures at the gas/vacuum interface)"
  • #44
Rarefaction wave is not a shock wave, and can't become one.
You need section "3.4.3 Hydrodynamic Shock Waves"
  • #45
nikkkom said:
Which particular phrase / sentence / paragraph should I read?
If you have a point to make then why not help the reader with where it is? Do you expect a casual contributor to top through the whole of that link and discover where your point is being demonstrated? Full marks to jerremyjon for finding it but should he have had to go to all that trouble? PF normally tries to be helpful, rather than to set people examination questions.
But it seems to confirm that this sort of thing doesn't happen in a free wave and must involve significant differences in the motion of parts of the medium.
  • #46
But I also strongly recommend reading the entire FAQ. You will increase your knowledge of nuclear weapons physics x100.
  • #47
Compression waves are fundamentally unstable. They naturally tend to steepen in time and eventually (if they propagate long enough) will become infinitely steep: a shock wave. On the other hand, rarefaction waves are stable and a rarefaction shock (a sudden pressure drop) is impossible.
3.4.1 Acoustic Waves
Any local pressure disturbance in a gas that is not too strong will be transmitted outward at the speed of sound.
  • #48
I can't think of anything for light yet, but perhaps for sound waves: Make a long bar consisting of layers of material that conduct sound at different velocities. If in fact that is a characteristic of different materials. Eg wood, plastic, metal. Then strike the bar on the end and then find some way to (visually?) observe the sound in transit or arriving at the other end of the bar. Guess I should research sound/shock velocities in different materials.
DC
  • #49
Yes. I realize I am somewhat 'under-read' about a lot of topics - this is one of them. There must be a lot of people like me who have dipped into the thread and a bare reference to a long and difficult link is not going to encourage them to follow it. I always reckon that some personal input is worth while. A paragraph in one's own words, even when it's at a lower level than really necessary, is worth while, just to keep a thread going and to address a wider audience.
  • #50
That picture made me realize that the surface wave that's set up when a boat is traveling at even a low speed, exhibits many of the characteristics of a breaking wave. The water at the top of the bow wave is traveling backwards, relative to the boat and the bow wave is continually 'breaking'. It makes me think that the equivalent must happen for other wave types but there is a very significant difference for water surface waves and that is they are very dispersive (speed is proportional to √λ - see link). You would need a very special medium for this with sound or EM, I think.
  • #51
If the boat is traveling slowly (i.e., less than the so-called "hull speed"), the bow wave can actually be fairly quite smooth (non-breaking), provided the boat has a reasonably fine entry and you aren't driving into much chop.
If you are getting close to hull speed then, yes, this starts to be reminiscent of a shock.
  • #52
Referring to low frequency radio waves:
Conductivity of the surface affects the propagation of ground waves, with more conductive surfaces such as sea water providing better propagation.[8] Increasing the conductivity in a surface results in less dissipation.[9] The refractive indices are subject to spatial and temporal changes. Since the ground is not a perfect electrical conductor, ground waves are attenuated as they follow the earth’s surface. The wavefronts initially are vertical, but the ground, acting as a lossy dielectric, causes the wave to tilt forward as it travels. This directs some of the energy into the Earth where it is dissipated,[10] so that the signal decreases exponentially.
www.jpier.org/PIER/pier19/02.970718p.Ling.SU.pdf
So, yes apparently EM waves crash in the same place that water waves crash due to the change in conductivity between shore and ocean water.
  • #53
Ground waves surprised early experimenters who expected much greater losses over the horizon for MF and LF waves. I can see how your analogy is attractive but ground waves are a linear phenomenon and happen the same for all signal levels. All that is happening is a tilted wave front so I don't think it really counts, unfortunately.
  • · Replies 18 ·
11K
  • · Replies 22 ·
  • · Replies 44 ·
58K
  • · Replies 48 ·
