Do Moving Charges Create or Induce Magnetic Fields?
rohit dutta
Do moving charges 'create' or 'induce' magnetic field around them?
I believe that induction is a phenomenon in which the behavior of one object depends on the behavior of another object provided they interact with each other. In this case, the moving charge is just surrounded by air or vacuum which plays no role in the process of induction. I thus say that moving charges create(and don't induce)magnetic field around them. Any corrections is most welcome.
Thank you.
In fact the electric field and magnetic field are parts of the same object "electromagnetic tensor" so in a frame where the charge is at rest we see only the electric part but in an other frame where the charge moves we see the two parts. I hope that helps
Thank you
Yes I completely understand what you are trying to say. But I'm trying understand the difference between what an induced and a created(generated) field is.
Dear
In my opinion, all fields exist, they are not generated or induced by the charges (in general). The charge is a measurable physical quantity giving the coupling of the particle with these fields. It did not induce the field. I invite you to think about how particles acquire an electric charge.
Thank you to read
In Faraday's famous experiment, a changing magnetic flux through a conducting loop did 'induce' an opposing magnetic field didn't it? Well, I've gone off topic to talk about induced fields. I agree with you about the existing fields around a charge.
Thank you.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
