Do Paper Contracts When Burnt?
  • Context: High School
  • Thread starter Thread starter ajayraho
    Paper
The discussion revolves around the phenomenon of paper contracting when burnt, particularly focusing on newspaper. Participants explore the physical changes that occur during combustion, including mass loss and changes in volume, as well as the effects of chemical treatments on paper over time.
  • Some participants observe that when newspaper is burnt, the writings appear smaller, prompting questions about whether the paper itself contracts.
  • One participant notes that burning paper turns it to ash, suggesting a complete transformation rather than mere contraction.
  • Another participant supports the idea of contraction, explaining that water in the paper is driven off by heat, which could contribute to a decrease in volume, although the extent of this change may vary based on the paper's composition.
  • There is a mention of carbon compounds being converted into gases during combustion, leading to a loss of mass in the paper.
  • One participant raises a question about the yellowing of paper over time, linking it to chemical bleaching processes and subsequent reactions that may alter the paper's color.
Participants generally agree that burning paper leads to changes in mass and volume, but there is no consensus on the specifics of how much contraction occurs or the implications of these changes. The discussion also introduces a separate topic regarding the yellowing of paper, which remains unresolved.
Some assumptions about the composition of paper and the effects of burning are not fully explored, and the discussion does not clarify the exact mechanisms behind the observed phenomena.
ajayraho
I have observed many times, that when a newspaper is burnt, its writings become smaller.
Do the paper really contract when burnt?
It's not clear what you are describing.
When I burn a newspaper, it turns to ash.
Hello Ajayraho,
I think your observation has credence.
The paper would have to get smaller and smaller as it burns.
For one thing all the water in the paper is driven off by the heat. The percentage change in volume night not be all that much, depending upon the makeup of the paper.
Next the carbon compounds are turned into gases that can burn with the oxygen in the air. So the paper itself is actually losing mass.
If you don't disturb the ash remaining, you can still sometimes read the now smaller print, at least where it hasn't curled up on itself.
the paper itself actually loosing massmoreove moreover there were water before in the paper and vaporized after burnt the peper. However paper are not pure elements so the VDW between particle actually maintain constant but number of particle decrease so the paper contracts.
256bits said:
Hello Ajayraho,
A very satisfying answer..
So what's the reason behind the yellowing of papers, when kept for a long period of time?
Hi Ajayraho
actually, paper are not white from the origanls. it is yellow, we use some chemical bleacher to bleach the paper, however, the chemical will left ln the paper and during a long time, the chemical on the paper will reacts with paper which give a yellow colour on the paper
  • · Replies 42 ·
  • · Replies 21 ·
  • · Replies 18 ·
