friend said:
As I understand it the symmetries of the SM continue to exist in any spacetime...?
There is a revolutionary new idea here that you may not taking count of. A new way to represent 4D spacetime that does NOT use a manifold. The manifold (a set of points, a set of maps, map overlap consistency, smooth functions defined locally, tangentspace at each point) was
invented in 1850 and is the math object everybody usually thinks of in this context representing a spacetime or any other continuum. GR was defined on manifolds.
But there is a more abstract way to present spacetime! In a sense it is simpler and more generalizable. You can present a spacetime as an abstract NUMBER SYSTEM! It is very unintuitive why and how you can do this until you get used to it.
I don't mean ordinary numbers--integers, reals, complex numbers---NO! but a set of abstract things not numbers but that you nevertheless can add, subtract, multiply. For example imagine the set of all smooth real-valued functions defined on the surface of a donut. An algebraic object: you can add or multiply two functions to obtain a third. And hidden deep in the combination rules of that algebraic object can still be a simple geometric object like the surface of a donut. An algebraist can find the hidden geometrical thing which is sometimes called the "spectrum" of the algebraic object. It is revealed to him by the way the functions defined on the donut add, subtract, and multiply with each other to give other functions
The good thing is that the algebraic object can be modified ever so slightly and then its spectrum will consist not merely of, say, the surface of a donut but so to speak a very fussy surface of a donut which will only allow to be defined on it functions which have a certain symmetry (like U(1)SU(2)SU(3), but perhaps not that exactly, some symmetry)
There is no more manifold, no set of points papered with overlapping maps, and the symmetry is in some sense "dyed in the wool" intrinsic in the spectrum of this abstract algebra system, the spectrum which would have represented an ordinary spacetime if it hadn't been generalized or tweaked.
So Connes and Chamseddine figured out how to mimic a spacetime with SM living in it (in this abstract way) and in the process they got MORE. they were able to extract predictions that you couldn't get from the ordinary SM.
They goofed on one of their first predictions (as they explain in the "Resilience" paper) overlooked an important detail. but that happens. So they found their mistake and now they have a "post-diction" instead of a prediction. the main thing is that their way of realizing the SM gives something MORE than just the Standard Model.
Also it is kind of elegant.
One of the regulars at BtSM, arivero, knows a lot about NCG (or spectral geometry as it is coming to be called) and can, I think, explain how you rig the algebra so that the U(1)SU(2)SU(3) SM arises from it. IIRC he has studied this some years back like 2007 and 2008.
Here is the first reference in the "Resilience" paper:
[1] Ali H. Chamseddine and Alain Connes, Why the Standard Model, J. Geom. Phys. 58 (2008) 38-47.
http://arxiv.org/abs/0706.3688
Ali H. Chamseddine, Alain Connes
13 pages
(Submitted on 25 Jun 2007)
"The Standard Model is based on the gauge invariance principle with gauge group U(1)xSU(2)xSU(3) and suitable representations for fermions and bosons, which are begging for a conceptual understanding. We propose a purely gravitational explanation: space-time has a fine structure given as a product of a four dimensional continuum by a finite noncommutative geometry F. The raison d'etre for F is to correct the K-theoretic dimension from four to ten (modulo eight). We classify the irreducible finite noncommutative geometries of K-theoretic dimension six and show that the dimension (per generation) is a square of an integer k. Under an additional hypothesis of quaternion linearity, the geometry which reproduces the Standard Model is singled out (and one gets k=4)with the correct quantum numbers for all fields. The spectral action applied to the product MxF delivers the full Standard Model,with neutrino mixing, coupled to gravity, and makes predictions(the number of generations is still an input)."
And here's their second reference:
[2] Ali H. Chamseddine and Alain Connes, Noncommutative Geometry as a Framework for Unification of all Fundamental Interactions including Gravity. Part I, Fortsch. Phys. 58 (2010) 553-600
http://arxiv.org/abs/1004.0464
